Question about Dryers
My indesit condenser tumble dryer is only giving out cold air. it is not heating up?
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
My indesit condenser tumble dryerwont start
try door interlock......................cheers
Oct 07, 2016 | Indesit Dryers
My tumble dryer isnt heating up
bad element or thermostats , check for continuity with multimeter, the thermal cut off and the hi-lo thermostat. Its electric right? if Gas need to check Flame igniter, glo bar, condenser coils, additionally
Sep 13, 2014 | Indesit Dryers
This indesit reverse action dryer (1S31V) has stopped blowing out hot air. I took the back off and cleaned the fluff which had clearly caused the problem. Is there a thermostat or fuse that I need to...
Hi. I have a Hotpoint tumble condensing drier which had the same problem. The solution for me was to access the heating element at the back which involved taking the back off and locating the small metal thermostat which is the size of a two pence coin and 10mm thick.There
is a small hole in the centre and all I had to do was press a fairly thick needle into the hole until there was a click which reset the
thermostat and everything was working fine. This problem does still occur now and again. By the way the heating element is attached
to the removed back with cables giving a clue which helped me find
the unit. Hope this helps Regards Peter
Feb 11, 2013 | Dryers
Indesit IS70C tumble dryer not heating
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 10, 2012 | Indesit IS70C Electric Dryer
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Indesit Dryers
No hot air being produced from my indesit condenser tumble dryer. It sounds the same as it normally does,although a bit noisier. No water being collected in the water compartment. ?
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Dryers
An indesit tumble dryer, only blowing cold air.
Most likely heating element or thermal cut-off is bad, or both.
Sep 14, 2017 | Dryers
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
Common faults -
Feb 24, 2008 | Dryers
Dryers Logo
423 people viewed this question
Top Dryers Experts
