Opening a Gateway Solo 2150 laptop
Hi, I have a Gateway Solo 2150 laptop and the screen turned white. When you press on one side of it the picture will come back on. I'm assuming there is a short in the wiring..I have taken it apart (the screen) and everything's connected and fine. I talked with a tech. and they said it could be a short, loose wire. So I'm trying to figure out how to open the laptop to check out the two wires and see if one may be loose. Can you help? Thanks for any help given.
I purchased a processor upgrade for my Gateway 2000 Solo laptop but can't figure out how to open the case. Can you shed some light on how to get access to the inside of this computer?
Thank you,
Jeff Laskowski
Here's how to open the laptop case on the solo 2150. i myself have the same computer and learned how to take it apart repairing the power jack. first unscrew all the screws that are visible on the bottom and back of the laptop. also remove the rubber feet under the laptop and remove those screws. after that look at the keyboard and look at the bottom edge of the key board. if you look very closely at the bottom edge you will see little tabs. if you stick a small flathead screwdriver down there you can pry it off. once you have that of you will see a silver panel. next to most of the screw holes are arrows. unscrew only the ones with the arrows next to them. you can then lift the silver panel out. once you have done that you need to locate and remove 6 black screws around the edge of the area that you removed the keyboard from. then carefully unplg the ribbon cable to the keyboard an the wire to the monitor. it should then come off. Good luck.
Posted on Jul 25, 2010
I found the answer on another wed site. I tried it on my Gateway Solo 1500 and it works! The extra screws are hidden on top. You carefully remove the small face plate around the power button. I used a very small screw drive to lift it off.
Opening Gateway Solo 1400
by Aelanna - 2/3/05 11:04 AM In reply to: Gateway SOLO 1400 by hunjibunji
I'm also an A+ certified tech, but I've done notebook service for a lot of years. I just finished opening up a Gateway Solo 1400 and it was NOT easy! There are no screws holding the keyboard on the bottom of the machine. You can get the case open about 95% and there will be one area stuck, in the back near where the screen cable goes into the unit. There is a hidden screw on the top of the case next to the hinge. To get to it, you have to remove the two screws that hold the plastic hinge cover and pry off the cover. I only managed to find it after removing the keyboard, the display, and the panel with the LEDs and power button. (The screws holding the keyboard are on the top of the machine, underneath the cover with the power button on it.)
Posted on Apr 23, 2009
    Problem Solver:
  • 9 Answers
Two ways top and bottom,
The top .. usually the keyboard pops off thus revealing wires, components
the bottom.. should have screws to open panels.
Posted on May 02, 2008
How can I open the case of gateway solo 2150? I
There is some information on FixYa for this already which can be found at the post below. Generally with a laptop, you'll have some hidden screws under a bezel on the top of the keyboard area. You gently pop this off with a small screwdriver and underneath will be the screws that hold the keyboard in. After removing these, you generally can disassemble the rest of the laptop.
http://www.fixya.com/support/t565004-opening_gateway_solo_2150_laptop
Mar 28, 2010 | Gateway Solo 2150CS Notebook
My lap top screen continues to flash white
Your driver or monitor is totally screwed up.Try to get some live cd i recommand u this one.
If it doeasn't work then is a hardware problem that i can't solve remotly.
Apr 01, 2009 | Gateway Solo 5300 Notebook
Gateway solo 5300
Look at these sites:
This is a good "how to" with pictures (although it doesn't show your particular model):
http://www.laptoprepair101.com/laptop/category/lcd-screen-repair/
This shows how to remove the keyboard for your model:
http://support.gateway.com/s/Mobile/Solo_Series/p5350/8508369/8508369.htm
http://support.gateway.com/s/Mobile/Solo_Series/P5300/P5300nv.shtml
http://support.gateway.com/s/Mobile/manuals/8508399/8508399.htm
Manual for your model:
http://www.supportspot.net/gateway5300.pdf
Oct 21, 2008 | Gateway Solo 5300 Notebook
Will not turn on
Hi
do one thing remove the battery from the notebook and unplug the power cable press and hold the power button on the laptop for 10 to 15 seconds. connect the battery and power , turn on the notebook, it should work
Good luck
May 25, 2008 | Gateway Solo 5300 Notebook
No sound since installing xp
You have to download and install audio drivers from this page here.
Mar 02, 2008 | Microsoft Windows XP Professional
How do I swap screens in Gateway 9300 Solo computer?
Before opening the laptops try easy things like swapping the memory. Also remove all cards underneath the panels you can get to (wifi. modem, etc) The machine will boot with just RAM inside it. This includes swapping batteries wich can cause failure. If you tried swapping basic parts. Video card and screens are the next step.
Replace the video card and the screen in the machine that  runs:
First, you want to get the two apart, the screen can be removed by locating the covers inside the lid where the screen is. Usually rubber feet or disc shaped plastic that matches bezel texture. slowly remove screws, also the hinges must be removed. The covers for the hinges usually pop off or are held be a screw in the rear of the laptop. The ribbon cable follows all the way down to the motherboard through one of the hinges, there is a way to guid it out of the hinge area. If you get lucky the screen cable connects to a
removable mini card which is your video card. The one with the
white screen may have a bad video card.
Jan 06, 2008 | Gateway Solo 9300 Notebook
Touchpad
pluggung in a ps2 mouse will usually isolate the TP.
Refer to your manual or customer support at Gateway
Nov 26, 2007 | Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB...
Computers & Internet Logo
921 people viewed this question
David Payne
David Payne
