Question about Tablets & eReaders
No cd rom drive
I have just purchased a web cam but i have to install the cd rom i got with it.... the problem is i dont have any disk drives in my pc at the moment. is there a way i can install my web cam without the disc?
    Guru:
  • 1,463 Answers
Hello donna 84
if you post make / model of web cam also your o/s winodws etc i will check see if any drivers for download , this way you can download them to pc .
riz.
Posted on May 02, 2008
  • 32 Answers
If the tablet pc has a usb port you can copy the contents of the cd to a usb flash drive, plug the flash drive into the tablet pc and run the setup file on the flash drive to install the webcam software to the tablet pc. Another option would be if the tablet pc has internet access go to the webcam manufacturers website and download the drivers and software for the webcam to you tablet pc desktop and install them that way.
Windows xp not start following file missing corrupt system32 confi
Restart the computer, and force it to boot from the Windows XP CD-ROM. Choose "Repair Existing Installation", and see if that fixes the problem.
It might be better to remove the disk-drive, attach it as a "slave" disk-drive in some other computer, and copy all your files onto an external disk-drive.
Feb 27, 2014 | Toshiba Portege Tablets & eReaders
I want to know how to reinstall toshiba portege m200
This is in case you cannot boot into windows but you can get into bios:
Open your disk drive. Insert windows operating system disk into your disk drive. Restart your computer.
If you can get to the stage where you can see see bios entry key then keep pressing whatever key it is that you press to get into bios at start up.
Select the option that let's you choose the drive to boot from, mine is in advanced bios options. then go to either something like bios features or change boot drive.select whatever drive represents your CD-ROM drive and select it to be the first boot drive.
then save exit bios, I do this by pressing escape then Y to save and boot from the rom drive.
This will let you restart your installation of windows and
re-format the drive...
If you can boot into windows:
Then either re-format the drive and delete the partition when you do or...
Run a recovery of the system by installing your disk and letting it get to the stage wher it asks what action/task you want to perform and press r when prompted then follow the prompts to repair the files. This might not work though,
you could even try running a disk check as maybe a lucky chance of repair if you can get into windows.
If your PC keeps trying to boot from the CD drive after repair then re-enter bios at start up and change your hard drive back to first boot device to boot into windows.
It's better if you re-format though as repairing windows can be a little tricky.
Aug 01, 2011 | Toshiba Portege M200 Tablet PC
We understand that your problem is: Hi please help me i dont know what to do i purchased a used compac tc1000 tablet pc on ebay for college and It had ubuntu installed on it and not windows xp it did come...
Hi First you need to make the USB CD-rom Drive as the first boot device by going to BIOS setup by tapping F2 when the system turns ON , after changing the boot order insert the first disc and restart the computer it should run from the disc.
Nov 28, 2010 | Compaq tc1000 Tablet PC
Toshiba 3505 not booting from usb cd rom
OK, Do 1 thing, start pc press del go in side of BIOS.
Set the 1st booting drive as USB CD ROM. and save that. then restart your system.
Jan 30, 2010 | Toshiba Portege 3505 Tablet PC
Hi, I have a T3010 Tablet pc Fujitzu Siemens
I removed harddrive from tablet pc and copied neccesary files onto drive via USB to IDE adapter. Then re-installed harddrive into tablet pc and now it works.
Oct 13, 2009 | Fujitsu Siemens LifeBook T3010 Tablet PC
My hard drive also failed. i cant install or repair the os on it.
the best way you'll need a USB CD ROM Drive so you can boot from USB with the windows CD in the drive and install from there.
Aug 10, 2009 | Compaq tc4200 Tablet PC
Boot up problem
this is a easy fix all you need is a windows xp installation disk.what you do is put the disk in and boot off of the cd option.if you need help with the xp cd installation i can write up a guide for you.also is the first harddrive new or came with the comp.if it is a new harddrive it might not have a operating system on it.email me if you have anymore qeustions or you want the guide.i can even make a video for you but it probably won't be good quality.
Apr 23, 2009 | Toshiba Portege 3500 Tablet PC
Disk error
Does the laptop have a usable cd/dvd rom drive?
May 13, 2008 | Toshiba Portege 3505 Tablet PC
Bootable cd / dvd
one possible way around is to copy the entire cd (make a new folder named "CD COPY" or similar) to your hard drive (assuming you have enough space...about 800 Mb), then run the install from setup.exe from the hard drive, then delete the copy (to make room) when you are done.
Mar 24, 2008 | Toshiba Portege M205-S810 Tablet PC
Loading Windows 2000 on a formated hard drive
Try detecting cd rom in bios and boot from Cd rom. and then istall windows.
If not you should have drivers in floppy during installation it will ask for drivers F6 [function key]
Best Regards
rafique
Feb 18, 2008 | Fujitsu Stylistic LT C-500 Tablet PC
Tablets & eReaders Logo
274 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
