My washing maching machine is very noisy and sounds like it is banging on a spin cycle. wot is it? it is ok when empty
    Sergeant:
    Champion:
  • 333 Answers
Usually caused by the drum being out-of -balance. Can be the result of poor distribution of the clothes or too light a load in the machine. Before the spin cycle starts, the drum usually rotates clockwise and anticlockwise to distribute the load evenly.
If the above is not causing the problem, it may be due to the concrete damping block ( present on most washing machines) becoming loose. This sometimes happens after a period of use, and can be easily corrected by tightening up the retaining bollts.
Finally the bearings could be worn. Repairs could be expensive if this is the case.
Before investigating anything inside the machine MAKE SURE IT IS DISCONNECTED FROM THE MAINS SUPPLY!
Posted on May 02, 2008
Hotpoint 1200 wd62n banging noise when loaded but ok when its empty ?
There are many reasons that this could be noisy...
When you turn the drum (quickly) when it's empty does it rumble? Bearings, drum support or motor bearings.
If it sounds like a pneumatic drill when filled and spinning it could be drum support, bearings, balance weight or suspension.
These are not an exhaustive list but the usual suspects.
Jun 02, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore 500 bangs when spinning
Sounds like the bearing in the drum has bust but shouldnt be too expensive to replace.
Nov 19, 2013 | Kenmore 24902 Top Load Washer
Bumoing sound in spin cycle
check to be certain your suspension springs havent shifted and or come off their mounts. also make sure the belt is properly tensioned, the washer is level, and that the bearings have not worn out.
Aug 14, 2012 | Whirlpool Washing Machines
My washing maching starts this banging and thumping on the rinse cycle
frigidaire front load washer bangs on the final spin badly
Mar 21, 2010 | Hotpoint Washing Machines
We heard a large BANG and now it is so noisy
The rear bearing in most front loaders lasts an average of 5 years under normal usage. Spin the drum manually with your hand and seee if it is nice and smooth and quiet. If the bearing is ok it is probable that 1 of the shocks is broken on the bottom.
Mar 18, 2010 | Washing Machines
In spin cycle, there is a loud metal on metal sound. could it be a bearing going out? the machine still spins but much slower, and the banging sound occurs in one place every revolution during the spin...
Hi
Remove the drum belt, and spin drum by hand.
If it feels rough, or it is noisy, then drum bearigs have failed.
Please rate my solution.
thanks.
Jul 24, 2009 | Whirlpool Washing Machines
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Washing Machines Logo
289 people viewed this question
Top Washing Machines Experts
