My printer want print I may not have it connected right I only have Two lines comming from my computer
    Problem Solver:
  • 9 Answers
And what lines are those? is printer brand new? or was it working before? brand/model and your operating system please...
Posted on May 10, 2008
My printer says it is offline I have a MacBook
Most printers you go into your computer where your printer is listed, find the printer right click mouse or pad, and you may see a line that says off line, click on it and many times it puts it back on line...
May 07, 2014 | Lexmark X7675 Wireless All-in-One Printer
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Apr 09, 2011 | Brother MFC-5460CN InkJet Printer
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
My printer won't print from my computer. It is connected right and I ran a Calibration page and printed a demo sheet and all was fine. When I go to print the block that pops up for the printer shows 2...
If your using windows XP go to start then control panel and on to printers and other hardware look for your printer, right click and set it as the default for your pc.
With windows 7 -- Start/control panel/hardware and sound and click printers then just right click the prineter you have connected and set it as default.
Jul 03, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer off-line
Hello my friend, see to it that your printer Epson Stylus is properly connected to your computer (USB Connection). Mostly when printer get off-line are not Power-ON, USB connection failure, or manually set to printer ONLINE. Printer are detected by your printer initially when power on or you may be hear some sound if the printer is connected or ready.
If not go to Printer Properties and manually select "PRINTER ONLINE". This are some problems that encounter with the printer.
Sep 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Cannot print; scanner, copier works fine.
whta may have happened is that the first print job has an error if yu right click on the printer on desktop you shoul see all the print jobs in line cancel the first job and see if the others print you can also go to printers on the desk top and right click on the printer go to properties and then port make sure it is highlighted for you connection type. you can also test print from here to cjheck connection. make sure it is set on the port for the correct connection either usb or tcip or parrallel and that it is connected as a -_local printer. good luck
Mar 18, 2009 | Brother DCP 7010 Multifunction Laser...
Printer stopped printing and says its off line!
Im Rizwan from India, i would to tell u to check few things that will resolve this problem
NO 1: Check the Connection and power
1.Check the USB cable and the power line to the printer.
2.unplug and replug the cables at the PC an printer end.
NO 2:Check the printer status in control panel.
1.Click start - >Run.
2.In the run window type "control" (without quotes).control panel will open.
3.In the control panel, look for printers and fax and check the printer icon.
4.If printer icon says Offline, Right click on printer icon and select "use printer online"
5.Try printing, if it didnt print follow step NO 3.
NO 3:Restart the USB Composite Device.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Try printing Now, if it didnt work please response.
Thank you
Dec 06, 2008 | HP DeskJet 722c InkJet Printer
HP 7410 off line with Vista & HPM8000 computer
Once right click on the printer icon and make it online and then clear the print que and then download and install the patch from the below webpage.
After installing the patch restart the computer and check for the result.
Jun 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Vertical line down right hand side
crop toy jpg or bmp file from that side and then try I faced smae type of problem that process helped me you also try.
Mar 18, 2008 | HP LaserJet 1012 Printer
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
