The wireless icon is not lit on the box and i can't get my wireless comp to start up
  • Edward Stewart
    Edward Stewart May 11, 2010
    What wireless icon? What type of computer are you trying to connect? Does it start at all?
    Problem Solver:
  • 9 Answers
What operating system are you using?
Posted on May 10, 2008
Any ideas on how to get my Vtech Vmotion controller to connect again?
take the batteries out of console. Hold the start button for 45 seconds. Put the batteries back in. Turn console back on. Controllers should work now.
Nov 14, 2011 | Vtech VSmile VMotion Wireless Controller
Our netgear wgr614v7 54 mbps wireless router has gone bad acording to our net work service.They tested there modem,that had astrong signal.now here is whats happnen,there is no signal frm modem to wireless...
This guide gives you the directions for setting up wireless on the Netgear WGR614v7.
Basically enter the routers ip address (192.168.1.1) in your browser. If you router has default configurations, then enter the username as "admin" and the password as "password." Navigate to "wireless settings" and then on that page you configure your network.
Jun 13, 2011 | NetGear WGR614 54 Mbps Wireless Router -...
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
Belkin Surf Network Adapter installed on my desktop connects to my wireless network and looks to be working ie. wireless icon in lower right hand corner is flashing blue with no red cross etc. However, I...
I got your issue , for your issue , I f you want to go online hard wired to the router , make sure the Local are connection in the comp is enabled as well you have coted that u can see red cross in the wireless network connection icon, so make sure do not have any preferred networks in the comp.
Thanks,
Prema
Sep 27, 2010 | Belkin F5D4070 Network Adapter
My wireless icon has disappeared on the task bar and the network icon on thedesk top will not activate - it was al working yesterday
there should be a switch or a button on you comp that turns the wireless on and off you must have accidentally switched it off.
Mar 01, 2009 | Acer Aspire One PC Notebook
My videos are dark and grainy
It's dependent on where the light is. If you're back lit your best bet is to check the box in the cam settings for backlight comp. (You can access the cam settings from the icon in the tray) If you're lit from the front using a lamp or something you don't need a lot a ton of light as too much light can white you out.
Dec 17, 2008 | Microsoft LifeCam VX-6000 Webcam
Icon shows connected but cannot surf net and receive emails
try this, turn off your pc then shut down your router then shut down the modem after 5 minutes restart the modem after all the lights are lit turn on the router after all those lights are lit start you pc, then go to my network icon and view network connections, then click on the properties tab high light the tc ip line and hit the properties tab click Obtain IP address automatically and the same for Obtain DNS server automatically. In the advanced tab in the IP address box have DHCP Enabled and check the box Automatic metric, in the DNS tab check Append primary and connection specific DNS suffixes and check the box to Append parent suffixes of the primary DNS suffix, at the bottom check the box Register this connection's address in DNS. In the WINS tab check the box Enable LMHOST lookup and click the Default in NetBIOS setting. Now having done this click OK and OK again then click the close tab for the properties window and then reboot your computer, you should be able to surf the net with out any problems.
Sep 10, 2008 | NetGear WGR614 Wireless Router
Wireless Internet Conection
The wireless adapter on your comp requires reinstallation of drivers.
For this if using windows xp click start>run>type in devmgmt.msc press enter> it will open up device manager in that window double click network adapters it will collapse the list and you'll find your wireless adapter listed in there right click on it and click uninstall and then restart your comp. It will reinstall the adapter drivers but you have to be careful while doing this because any wrong step can uninstall the device completely.
Apr 13, 2008 | Computers & Internet
Vista OS can't connect wireless to Dlink DI-614+ rounter
yes it does but what exactly is this it's your comp that's not connecting to your wireless network..so here try these steps...
first click start>click in start search>in that box type in services>it gives you an option of services on the same start menu at the top click on that...
it will take you to a new screen that says services at the top on that screen you need to scroll down at the bottom and look for wlan auto configuration rt click on it and click start if start is greyed out press restart....
close services down..
click start>click connect to form the start menu> and check it gives your network name in there .if it says anything like no network found in range. pls make sure that wireless switch on your laptop is turned on...
if still you're not able to connectr it's a concern with the drivers of wireless adapter on your comp genrally on new comps its quite common get the drivers reinstalled....
Feb 18, 2008 | D-Link AirPlus DI-614+ Wireless Router
Wireless router not found broadcasting to another comp
Quick check.... By the Power button There should be a light that says Wi/Fi (It should be lit) if not Press The Fn (Function Key) Is it Lit now? This is a common Problem. Also Some models have a an Switch on the side of the laptop to enable and disable that wireless Devices....
Jan 15, 2008 | Dell InspironĀ® 1501 (N11157) PC Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
