Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Volume toggle switch broken
My son couldn't adjust the volume, so I tried as well. It seems that the toggle switch is permanently pressed into the down volume. The volume is all the way down, so nothing can be heard! Is this fixable or do we need to just buy him a new mp3?
    Problem Solver:
  • 12 Answers
The only way you could try to fix it is if you opened it up and checked it out from the inside.  if nothing wrong inside, then it is something wrong with the motherboard and you will have to buy him a new one. but if you get it open then you can pop the toggle switch into place and it should be fine
Posted on May 02, 2008
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
(enter BootLoader)
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
Dv7-1023cl problems with quick touch buttons
You don't need to activate the drivers. if you reinstalled them then they are there and should be working.
There should be alternate methods to using the quick touch keys, such as using the conventional methods.
For example to change your volume, just click on the megaphone at the bottom right near the time and adjust the volume. Or click Start/Control Panel and look for Audio or Sound and adjust the volume. Also click Start/Programs/Accessories/Entertainment and see if there is a volume control there. Also normally you can adjust the volume by keystrokes. Normally you would Press and Hold the FN function key near the bottom left portion of the keyboard and press the volume keys (there should be 3 volume keys, volume up, volume down and volume mute).
As for the Wireless there is a switch on the side or in the front of the laptop that controls the wireless. Also there are keystrokes that can toggle it off or on once the wireless switch is on. Normally you would Press and Hold the FN function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the icon of a wireless signal )))) or it will have the icon of a tower with a wireless signal )))).
Apr 23, 2012 | HP Pavilion DV7-1023CL Notebook
We have the Graco two room monitors, says Graco A5220. Our son got ahold of the parent unit, and now the unit will tune in to the room for a short time, then seems to be looking for the other room which is...
1- Set the room switch to the room you want to disable.
2- Press and hold the "stopwatch" looking button on the left side of the monitor.
3- While still pressing the stopwatch button, press the volume down button until there is only 1 LED left on the display.
4- Release all buttons.
5- Change the rooms switch back to the room you are monitoring so you can change the volume if desired.
Sep 13, 2011 | Graco Toys
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 | Cell Phones
How do I set the clock on my '98 Saturn SL1?
press and hold the power button and the use tune up and down to set it
Oct 05, 2009 | 1998 Saturn SL
How to adjust volumetrics? brand new wega 2 group semi... i need instructions to re program the timer setting and cant remember how thanks
Depending on the model behind the front panel just above the right steam valve, there will be a little toggle switch labeled On and off. Turn that to On then hold down the program button until all lights are lit press button you want to program when you get the desired volume press stop button, light on programed button will go out. When done move switch back to Off.
Sep 01, 2009 | Coffee Makers & Espresso Machines
Serviceman mode for sub brightness (D02) adjustment PT-53WX42F The default setting is too dark. Need to increase but I cannot find where to change the Sub Brightness adjustment setting.
Remote Method
  • In SET-UP icon, set antenna to CABLE
  • In TIMER icon, set sleep timer to 30
  • Exit menus and tune to channel 124
  • Adjust volume to 0
  • Press volume down (VD) on control panel and red 'CHK' will appear in the upper left corner
  • To toggle between Serviceman and Aging Modes press Action and VD on the control panel
Jun 16, 2009 | Panasonic Televison & Video
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
FACTORY RESET METHOD (not permanent)
1 Go to the Menu
2 Get to the Settings Menu
3 Select <yes> to Reset to Factory Settings.
Have recently heard complaints of this method not being permanent, as this is needed whenever they want to watch a DVD. Also, radio and screen angle presets are lost.
1 Insert Audio CD
2 Press PLAY
3 Press STOP twice on remote
4 Enter 26604 on remote
5 Press ENTER
6 Take out Audio CD and Insert a DVD
DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
The 3rd method seems to work with most of the duals
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 18, 2009 | XO Vision XOD1742BT Car DVD Player
C/d car player
Push the left toggle in. It will go through different preset modes, then it will let you adjust things manually.
I find it helps to keep the Beep function (in the standby menu) on so that you can keep pressing the toggle and know when you're back on volume. It's easy to press by accident.
Jan 16, 2008 | Kenwood KDC-MP205 CD Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
