FixYa.com
Tags:
GE Supermicro X6DA8-G E7525 EM64T S604 Dual Xeon PCI-Ex/SATA/DDR/U320/EATX Mainboard  Motherboard
WHICH MOTHER BOARD SUPPORT em64T INTEL ?
posted by MOKRI on May 02, 2008
HI
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 02, 2008
Not Rated (0)
VAJohn
Rank:Wiz Wiz
Rating: 89%, 16 votes
All major motherboard manufacturers offer this support on most boards. The em64T indicates the processor is capable of running 64-bit operating systems and software. Do you already have a processor and if so what model is the processor? Based on the processor model you'll need to select a motherboard that has the correct socket type and bus speeds.
Comment by VAJohn, posted on May 02, 2008
I notice in the header you are referencing a supermicro system. They are a server manufacturer. The Xeon processor requires a motherboard that will support that cpu. Since this is a server I recommend if the current motherboard is bad that you acquire a new one directly from Supermicro.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
link is broken
hi srinubabu epox ep-4pdaei... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Motherboards
je veut des instrustion
instrustion pour le produit:... Answer This...
Motherboards
MOTHER BOARD
dear sir i have a qss-3300... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
