Question about Vacuums
Beko wma510s washer sometimes does not spin at the end of a cyle leaving the washing very wet.
  • 328 Answers
Check that the filter in your washing machine has been cleaned out. If there is no filter fitted there could be a kink in the back tube which takes the dirty water solution out to your drain.
Posted on May 09, 2008
Electrolux ew910t
Are your loads spinning even if off balance it will cause the drum to spin off balance and water will come out of the bottom
Jul 10, 2013 | Vacuums
Fan working, compressor does not come on
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 31, 2010 | Vacuums
Why wont my kirby carpet cleaner pick the foam and water off the carpet leaving my carpet soaking wet?
Is the carpet washer attached to unit is the belt hooked up? don't use the vacum head you well get shocked.be careful
Jul 26, 2010 | Kirby G6 Bagged Upright Vacuum
Do I take the filter off when I am vacuuming up wet things?
If it's a paper filter, take it off. If it's a cloth filter that can be washed and dried, leave it on. Your machine will have a float to close off the suction when the tub needs emptying. Anyway, air from the tub only goes through the turbine, not through the motor itself, so you need not worry. It's good practice to run the vac dry for a few minutes after using it wet, just to make sure the turbine's dry.
Aug 15, 2009 | Craftsman 17026 Wet/Dry Vacuum
Rainbow se trying to fix
small red washer on top - motor is the top. Also on only everyother fan spins.
Small fan with the small hole up
Barrel Spacer
Large Fan with the the hole down
Hour Glass spacer - this spacer has a washer welded to the bottom of it - spacer down!
small fan hold down.
Lower motor housing
Hope you changed the bearing while you were where here.
Give it a spin by hand and make sure there is no grinding.
Hope this is right, doing it from memory, have a picture at work.
Good luck
M
Sep 23, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Beko wma 665 w washing machine error code -c.l-
hi
my problem is when I try to use the machine I found the thatit didn't produce water to wash the colse ,just the washing machine start to work wiout water even I 've checked all the valve leeding te water to it.
Aug 04, 2008 | Vacuums
H300 brushes won't stop spinning even though I switch it from "wet scrub" to "wet/dry pickup" and is leaving streaks on the floor. I have already ordered a new squeege, but that won't take care of the...
Make sure you REALLY pull the lever controlling the brush spin all the way up. On mine I REALLY need to force it to the top. If I don't use enough force and it's just a tiny bit below the top, the brushes continue spinning. I wish it was easier to flip from one mode to the other but mine has always been "stiff". Hope this helps. It took me a while to figure it out. Once you get the hang of using it, it works GREAT!
Jun 11, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Brush assembly will not spin at all.
The turbine is bad, that is what drives the brush roll. You either replace it, sometimes you can take the turbine apart and clean it, alot of times they just get gummed up and won't work. Number 23 is the turbine.94b67a6.jpg
Feb 18, 2008 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
Nov 30, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
129 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
