Question about Samsung SyncMaster 510N 15" LCD Monitor
Help 1. driver vga i have install 2.i have try to adjust in screen properties also same 3. i have plug this monitor to other computer also same coming out messanges said optimun mode recommedation output 1024X760 60Hertz whatever i have adjust this display that he recommedation also same?????help??????...........
  • Samsung Master
  • 13,433 Answers
Its possible that the inverter in the screen is failing, I recommend you take the screen to a tech to be checked whats the problem with it.
noting more I can do.. from other side of the world with text :-)
Posted on May 02, 2008
Monotor screen not stable
Hey, can we get a little more information, laptop, pc, windows, mac, linux, new hardware, are you using anything like a DVI to VGA adapter?
As a generic fix for monitor problems:
1) if you just installed a new video card, new monitor, or video card software, the drivers may not be stable or compatible and you may need to roll back your drivers.
Right Click on "My Computer", click "properties", click the "hardware" tab, click "device manager", expand "display adapters", there should be a video car listed, go to "properties", (click the resources tab and see if there is anything in the "conflicting hardware list" at the bottom) to make sure there are no hardware issues" click the "driver" tab and click on "Roll Back Driver" It should prompt you, click Yes/Ok, restart your computer.
2) -OR- You need to installed drivers for your monitor to check this,
Right Click on "My Computer", click "properties", click the "hardware" tab, click "device manager", expand the "Monitors" tab, Check to see if your specific monitor manufacturer's name and model are listed. If it just says "Default Moniter", "Default plug and play monitor", or "plug and play moniter" you will need to check the disk that should have come with your monitor, -or- the manufacturer's website. Install those drivers as prompted by the manufacturer.
3) -OR- your monitor settings are incorrect, such as your screen resolution is set to something that your monitor does support, or your refresh rate is set out of range of your what your monitor supports.
This fix is quite different depending on your OS, so if its none of the above, please let me know, and I can give more specific advise.
4) Also please note, that sometimes, if you install a new video card, drivers are compatible, everything else is correct, but your power supply on your computer is not large enough to support it, your monitor can flicker, cut out, cause your computer to lock and freeze.
Feb 08, 2013 | Computers & Internet
Attention autoconfig please wait -- this message keeps popping up in the monitor continuously. it also adjusts the contrast anf brightness some times automatically. please help
Sounds like the "auto config " is built in to your monitor. It selects screen sizing based on the resolution, sync timing, refresh rate, etc... that your video card is adjusting on the computer.
I would suggest you to try changing the resolution in Windows and see if still receive the alert.
For more information on Screen resolution and display on monitor, check the below Microsoft Help & How-To Articles:
1:
Change screen resolution :-
http://windows.microsoft.com/en-us/windows-vista/Change-screen-resolution
2: Getting the best display on your monitor :-
http://windows.microsoft.com/en-US/windows-vista/Getting-the-best-display-on-your-monitor
3: Troubleshoot monitor and video card problems :-
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-monitor-and-video-card-problems
If it is doing it often and you are not changing screen resolution I would say the monitor itself might have issues. It's possible your display driver may be corrupted. I would suggest you to download and install the latest drivers for the Monitor from the manufacturer's website.
For more information on Updating a Driver and fixing driver problems, check the below Microsoft Help & How-To Articles:
1: Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows-vista/Update-a-driver-for-hardware-that-isnt-working-properly
2: Tips for fixing common driver problems
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-driver-problems
Check the plug and cable, look for bent pins or pins pushed in.
Are you using one of those DVI/VGA adapters? If your monitor has dual inputs (DVI & VGA) have you tried using the other input?
Anyway you could check if the issue exists when the monitor is connected to another PC? Or maybe try another monitor on your PC?
source: answers.microsoft.com
Mar 12, 2011 | Computers & Internet
Is it possible for me to remover the on board screen of my laptop(MX 6956) in order to use the keyboard and HD with an external monitor?
You don't need to remove the LCD screen.
1) Laptop off connect the external monitor's VGA cable, to the VGA port (Connector) on the back of the laptop.
The VGA port looks like this,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
2) Turn on the laptop.
3) Plug the external monitor into power. Windows will recognize it as an new hardware device.
Windows will search through it's database of Drivers, and match one up.
However, if you have the installation disk that comes with the monitor, install it now.
Load the software.
(The monitor's Installation Disk (CD) has the proper drivers. It will set the resolution settings at the correct resolution for the monitor. If you do not have the Installation Disk, download the drivers from the monitor's manufacturer website)
4) Once the drivers are installed immediately Right-click on an empty area of your desktop screen.
Left-click on Properties.
5) Now Left-click on the Settings tab.
6) You will see two rectangular shaped icons. One icon has a 1 in it, the other icon has a 2 in it.
The icon with a 1 in it represents your Primary monitor.
The laptop's LCD screen.
The icon with a 2 in it represents your Secondary monitor.
The external monitor you just hooked up.
Right-click on the 2 icon, then left-click on Attached.
Go to the bottom Right, and left-click on Apply.
Now go to the bottom Left, and left-click on OK.
Oct 21, 2010 | Computers & Internet
Display AL 1717 input not supported
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there!
This usually happens when switching from a CRT to an LCD monitor. If your monitor is new and you are connecting for the first time, reconnect to the old monitor, set the resolution to its lowest setting (usually 800 x 600), shut the machine down, plug in the new monitor and boot the desktop to watch the screen.
If you are unfamiliar with how to change the resolution, here are the steps to do so:
1. Right-click on the desktop
2. Select Properties
3. In the Settings tab, click and drag the Screen Resolution option to its furthest left position.
4. Click Apply and OK.
If this doesn't fix the problem, it's likely that there is a driver conflict. If you still have the old monitor, or if you have another CRT available, boot up again when connected to the CRT and perform the following steps to remove the old drivers from the machine:
1. Click Start
2. Right-click My Computer
3. Select Manage
4. Select Device Manager
5. Expand Monitors
6. Right click on the monitor you wish to uninstall and select "Uninstall"
7. If there are any other entries, uninstall those, as well.
Then shut your machine down, plug in the LCD monitor and boot the machine.
If the above mentioned steps don't help, try switching the type of cable used to connect the monitor to the desktop. If you are currently using a VGA cable, try switching to DVI (depending on how old your graphics card is this option might not be available). If using DVI, try switching to VGA.
If the LCD monitor manages to work, I would recommend you verify the proper drivers are installed. To do this:
1. Click Start
3. Select Manage
5. Expand Monitors
6. Right click on the monitor you wish to update the drivers for and select "Update Driver" (you will need to be connected to the Internet for the automatic update to work)
7. Select "Yes, this time only" and click Next
8. Leave the default option selected on the next screen and click Next.
If the automatic driver update finds no match for the hardware, you may need to download the driver and install it manually. Click HERE to download the driver for your monitor.
Save the file to your desktop and extract the file to your desktop. In Device Manager, right click on the Acer monitor and select Update Driver.
Select "Yes, this time only" and click Next.
Select the Advanced option on the next screen and click Next.
Check the checkbox next to "Include this location in the search:"
Click Browse.
Minimize any option currently expanded and search for the recently extracted folder underneath "Desktop".
Expand it and select the folder inside.
The OK button should now be available. Click OK and click Next.
The driver should install and your monitor should function normally from that point forward.
If none of those options work, you might want to think about opening a support case with Acer or returning the monitor for one that is comparable.
I hope I was able to help you! If you have any questions, please feel free to respond.
Aug 30, 2009 | Acer AL1717 17" LCD Monitor
Screen will not display
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Jun 29, 2009 | Acer H233H bmid Monitor
Fpd2275w monitor problem
Have you unplugged the power cord for 2 min. Try that, there are problems with these "locking" and unplugging sort of "reboots" them.
Jun 01, 2009 | Gateway FPD2275W LCD Monitor
Can't get external monitor to work properly
  1. Right-click on your desktop (anywhere there is not an icon).
  2. Click Properties.
  3. Click the Settings tab.
  4. You should see two monitors with a "1" & a "2."
  5. Right-click on "2" and click enable
  6. Your external monitor should come to life.
  7. You may want to make some adjustments with the resolution, and this option is on the same screen.
Apr 23, 2009 | Computers & Internet
I changed Desktop resolution setting to higher, Monitor went black with "Out of Range" message
please try this:
To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
2. Right-click the desktop, click Properties, and then click Settings.
3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
3. Click Advanced, click Adapter, and then click Change.
4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
6. Click Standard Display Adapter (VGA), and then click Next.
7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
9. Click 256 colors, click Apply, and then restart the computer.
10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
11. Click Device Manager, click View devices by type, and then click Display adapters.
12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
13. Install all updated monitor drivers.
hope it helps!
Nov 02, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Screen goes black then says VGA then says No connection
1. Video Driver (download the latest video driver for the video maker)
2. Wrong resolution is being used. try step 3
3. Use a lower one 800x600 or 640x480
4. Monitor can't handle the Video Card set to the max try step 3
5. Video Card is faulty (replace it)
Aug 02, 2008 | Gateway FPD2275W LCD Monitor
Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
Apr 28, 2007 | XFX GeForce FX 6800 (256 MB) Graphic Card
Samsung SyncMaster 510N 15" LCD Monitor Logo
59 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
