Question about Apple iPod MA446LL/A MP3 Player
Floydsmith41@yahoo.com my ipod won't sync what can i do ??????
  • Apple Master
  • 13,433 Answers
IPod Touch-1.1.4 (8gb) can you tell me the procedure for up-grade/sync (?) for my iPod ? ......Thank you. Frederick Harris (lazarus60@yahoo.com)
iPods can be upgraded or synced by using iTunes. If you have a Mac, this is a relatively easy process; with Windows, you will have to first download iTunes. If you don't have a computer, you could always upgrade or sync through a computer that has admin access from a trusted friend.
May 30, 2014 | Audio Players & Recorders
Ipod classic won't sync with itunes 10
Restarting your computer is often the solution when your iPod fails to sync with your iTunes music library. But if this fails, there are other troubleshooting steps to take.
Recharge your iPod via a USB cable connected to your computer or AC adapter. b> Click the help menu in iTunes and check for updates. Follow the onscreen prompts to download and install the latest version of the software. Open the new version of iTunes. Click the name of your iPod in the source list and check for updates under the summary tab to update your iPod. Attempt to sync your iPod with iTunes. Slide your iPod's hold switch to the hold position and then to off. Press and hold the menu and center buttons simultaneously until the Apple logo appears to reset your iPod. Open iTunes on your computer and reconnect your iPod to try to sync it with iTunes. Restart iPod service b> Close iTunes and make sure your iPod is disconnected from the computer. Click the 'start' button. Click 'run' if using Windows XP. Type 'services.msc' in the run box in XP and in the search box in the start menu in Windows 7 and Vista. Press 'enter.' Scroll through the list and double-click on 'iPod service.' Click the 'stop' button and leave the properties window open. Connect your iPod to the computer. Open 'my computer' or 'computer' and look for your iPod listed in the devices with removable storage section. Click the 'start' button in the iPod Service's properties window. Open iTunes to attempt to sync your iPod. Close the iPod Service's properties window once your iPod has finished syncing. Resolve "Original File could not be Found" Double-click the name of a song in the iTunes program that failed to sync to your iPod. Click 'yes' or 'locate' to the message asking you if you want to locate the file. Navigate to the folder or directory location where the song is stored on your computer. Double-click the song file to select it and add it back to iTunes. Reconnect your iPod to the computer and open iTunes to restart the syncing process. Some songs in iTunes won't copy to iPod http://support.apple.com/kb/TS1420 iPod classic Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/classic/
Apr 12, 2013 | Apple iPod MA446LL/A MP3 Player
Ipod classic 7th generation won't sync
Step 1:
With iTunes software, iPod users can manage their media libraries, purchase or import new content and synchronize their devices. The software has a number of convenient features, one of which is AutoSync. This feature will cause your iPod to automatically synchronize with iTunes immediately upon connecting the device to your computer. You can also set up iTunes so that you can manually sync your iPod.
Press the "Shift" and "Ctrl" keys on your computer keyboard simultaneously while you connect your iPod to the computer using its USB cord. Mac users will press "CMD + Option" while you connect. Continue to keep the keys pressed down while you monitor the iTunes window. Keep the keys pressed until you notice that Auto-Sync has stopped and your iPod icon has appeared in the Source pane of iTunes. Be patient, as this could take between 5 and 30 seconds. Right-click on the icon for your iPod in the Source pane, and then select "iPod Options." Click to put a check mark in the "Manually manage songs and playlists" check box. This finishes your task and you can now manually synchronize your iPod whenever you wish by simply clicking on the "Sync" button.
http://chris.pirillo.com/ipod-tips-and-tricks/
Feb 10, 2013 | Apple iPod classic 7th Generation
Error code 13019
look at the article on this forum it should help you http://support.apple.com/kb/TS2830
Dec 07, 2011 | Apple iPod touch
I HAVE AN ITOUCH AND USE YAHOO CALENDAR. HOW DO I SYNCH THEM? SHOULD I USE MOBILE ME?
If you are running iOS 4.x software or newer
  1. Go to the ipod touch settings application
  2. Tap Mail, Contacts, Calendars
  3. If you have a Yahoo mail account setup click on that account and turn on the calendar sync option
  4. if you don't have an account setup, click Add Account and then click Yahoo
  5. Fill in the fields requested and click Next
  6. If you are successfully logged in you will be allowed to turn on and off specific sync services. make sure that calendar is in the on position
  7. The next time you open up your ipod touch calendar you will see a page allowing you to select which Yahoo Mail layer you would like to view or edit
If you are running iOS 3.x
  1. Go to your iPhone or iPod Touch settings application.
  2. Tap Mail, Contacts, Calendars.
  3. Tap Add Account.
  4. Tap Other and then tap Add CalDAV Account.
  5. For the Server you can simply type yahoo
  6. Now enter in the Yahoo! ID and password you use to sign in to your Yahoo! Calendar
  7. Once you click save, the iPhone or iPod Touch will verify your Yahoo! ID and password.
  8. The next time you open up your iPhone or iPod Touch Calendar you will see a page allowing you to select which Yahoo! Calendar layer you would like to view or edit.
Mar 01, 2011 | Computers & Internet
How do I sync my Yahoo contacts and calendar with my iphone?
configure the out look express for yahoo and sync the outlook express with the yahoo mail then sync your iPhone to update the yahoo contacts.
Jul 22, 2009 | Apple iPhone Smartphone
How to sync .ipa files from comp to iphone thru itunes ?
when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
Setting Up Syncing You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
Step 1: Connect iPhone or iPod touch
  1. Connect iPhone or iPod touch to your computer using the included cable. You can connect the cable from your computer directly to iPhone or iPod touch, or connect the cable from your computer to the Apple Universal Dock (available separately) and put iPhone or iPod touch in the dock. By default, iTunes opens automatically.
  2. Select iPhone or iPod touch in iTunes under Devices on the left hand side and click the Info tab.
Step 2: Set Up Which Items Are Synced Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
For more information about syncing iPhone with your computer see the iPhone User's Guide:
On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
For more information about syncing iPod touch with your computer:
On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
Step 3: Sync iPhone or iPod touch Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Apple iPhone Smartphone
IPod won´t sync
Could be a loose hard drive connection cable on the inside. Could also be some corrosion on the USB connection. Try a different cable. Put your ear to the back and listen for clicking noises from the iPod - if you hear it you might have a warranty issue with a bad HDD. Attempt a restore. Worst case, try to get it evaluated by a technician - do not try to open an iPod Classic yourself- you will most likely cause permanent damage.
www.vaxtex.com
Jul 08, 2008 | Apple iPod nano 3rd Generation
Apple iPod MA446LL/A MP3 Player Logo
16 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
