Question about Motorola Mobility RAZR V3x Cellular Phone
Phone turns off
Sometimes when I receive a call phone get stuck and I have to remove the battery pack and restart it.Also sometimes the phone turns off.I have two battery and same thing happens with both.
  • robsmith34 May 06, 2008
    I have just installed a Monster pack on the phone and same thing happening.If I remove the memory card it does not changes anything.
Check out the memory if its very high the phone will get stuck and have to remove to restart it and also update your software regularly.and install an antivirus pack.
Posted on May 02, 2008
Battery stuck on Pride mobility scooter
Hi. There are no locking devices on the GoGo Elite Traveller series of scooter. The Battery pack simply lifts off. However, they can be very tight and sometimes require a sharp tug upwards to remove them.
Hope this helps.
Jan 02, 2013 | Pride Health & Beauty
My phone is frozen! It is stuck on this msg. "Samsung SGH-T249". No matter which button I push, nothing happens. It will not turn off, nor can I make outgoing call. The screen stays...
Press and hold the power button until the unit turns off. Sometimes it takes up to two minutes to turn off. If you cannot get it to turn off using the power button, open the back and take the battery out. Press and hold the power button for sixty seconds with the battery removed to reset the unit. Then reassemble it and turn it on. This may not solve the problem on why your screen is getting stuck but it will reset and allow you to attempt to restart it.
Aug 16, 2011 | Cell Phones
My phone is not able to connect through pz via usb
USB NOT RECOGNIZING PHONE
Cell phones use the popular USB connection which sometimes produces errors while connecting. These messages are similar to the "Device Not Recognized" error received with various USB devices. Fixing a cell phone is sometimes specific to the brand, but they are so similar that most can be fixed the same troubleshooting steps.
instructions
Device Manager
Click "Start" and go to "Control Panel." Double-click "System" and locate the Hardware tab to find the Device Manager. Vista and Windows 7 users can just type "Device Manager' from the start menu.
Locate "Disk Drives" from the list and double-click "Portable Device." If there is an exclamation mark or other error on the device, go to the "Drivers" tab.
Click "Uninstall" and remove the player. Restart the computer and attach the player reinstall the drivers.
Anti-virus conflicts
Plug the player into a different computer to see if it gets recognized. If it does not, contact the manufacturer to find out if it is broken.
Turn off your anti-virus program on your PC if the device works on other computers. Reinstall the drivers using the device manager as described in section 1.
Plug in the player to confirm the connection.
Other solutions
Check the battery level and make sure the batter is not low or depleted. A low battery will sometimes prevent the player from connecting. Let it charge from the power cord, if necessary.
Verify that you have at least Service Pack 1 installed. Go to the Start menu and type "Run." Press Enter.
Type "Winver" in the box and press "Enter." The Windows version will be displayed along with any installed service packs. Download a service pack from Microsoft, if applicable.
Remove the player from the USB port and push a pin into the reset hole located on the bottom. Reconnect to see if the problem is resolved.
Check the connection to make sure it's secure. The cable should fit firmly into both the player and the computer. Connect to a different USB port if you have one available.
Tips & Warnings
A bad cable will sometimes prevent a good connection. Use a different one to isolate the cause.
Jul 18, 2011 | Nokia 6300 Cellular Phone
Why my pc can't charge my phone using a usb cord
Instructions
Device Manager
Other solutions
Tips & Warnings
Jul 18, 2011 | Motorola Mobility RAZR V3i Cellular Phone
Some times the phone signal freezes (it shows some lines of signal but you cannot receive or make calls). I usually turn it off and on again and it starts to work but sometimes it is not turning off,...
remove your battery and leave it out for around 5minutes, when you put the battery back in, the phone should auto reboot, hence sorting out any problems it has, if this fails, contact BLACKBERRY DIRECT, they should solve the problem for you with a secret menu!!
Apr 30, 2011 | RIM BlackBerry Bold 9700 Smartphone
Can call,but can't receive calls rings a few times then disconnects as 'Number Busy"
Have you tried shutting down the phone, removing the battery. Leave it out for a few minutes, put it back in and restart the phone. Sometimes the phone processors lock up and need rebooting.
Feb 08, 2011 | Samsung Wave S8500 Smartphone
My phone just randomly turns off.
i had the same problem, but not the same phone. what i did was take out the battery for about 24 hours. when i put it back the next day it worked fine. hope it works out for you. :)
Jul 30, 2009 | Samsung Propel A767 Cell Phone
Pantech Duo. Phone stuck on "At&t" and can't restart. other options?
mine did this to i plugged it into the charger then put the battery back in and it worked then i had to master clear and it stopped causing doing that though it still restarts on its own sometimes.
Apr 19, 2009 | Lands Phones
My n70 always restart by its own...always freeze
turn your blueetooth on and you see that it will not stuck
Jan 07, 2009 | Nokia N70 Cellular Phone
Message Stuck in Outbox - and Cannot Send Text
First you have to cancel it and the under the more option move it to drafts and the restart phone
Nov 09, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Motorola Mobility RAZR V3x Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
