Question about Primera Technology Bravo II DVD Duplicator (62743) DVD±R Burner
Bravo II disk pickup problem
The unit does not see a disc, I have tried the utility, reset to factory settings, tried manually setting the robotics. All have had the same result NOT WORKING. I checked to see if the table was level and I adjusted as needed. Anyone have any Ideas??
  • gizmo72 May 11, 2010
    You can replace the Plextor drive with a Pioneer 112 to 116 all of these will work fine in the Bravo II
  • Paul Barkley May 11, 2010
    I'd like to know what drive you used. My Bravo II had a Plextor PX-230A (CD, not DVD) drive in it. I couldn't find a replacement so I bought a PX-240A, and it physically won't work. The tray needs to come out another 3/16th of an inch--I've adjusted the position of the drive in the "rails" as far as it will go, and on this model the tray just doesn't open far enough. It would be a pain using this by hand, and in the Bravo the arm can't clear the edge of the drive to pick the disc up vertically.
    I have a couple other drives I can try, but I'd like to hear any specific models that may have worked for other people. BTW, the factory says you can't put a DVD drive in a machine with a CD, because the motherboard needs to be changed. That's why their DVD upgrade is so expensive.
    Thanks for any help!
Chances are your burner is probably going/gone bad. Simply open the system carefully and replace the drive. Worked for me! hope this helps.
Posted on May 12, 2008
How do I do hard reset to factory settings on mac
Much like a PC, there isn't a magic button to do a factory reset on the computer. If you're unable to use the current hard drive, you'll need a bootable disc and boot holding the option key to select it as a boot disk. If the drive is bad, you'll need to replace it.
Dec 10, 2012 | Computers & Internet
Back to factory setting
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
You'll need to read your manual to see how to start the Factory Setting. Look for the manual on your manufacturer's website.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for Factory Restore or System Recovery.
May 29, 2012 | Acer Computers & Internet
I WOULD LIKE TO RESTORE TO FACTORY SETTINGS TY
You will loose all data you have put on the computer. When you turn it on right at the beginning there is a black screen and there are a few f key options.
They will flash up with the option when you turned it on, before windows kicks in. Take a look at the user manual to find out for sure.
Press the correct f key before windows starts up, then go through the menus in setup (it will look all crappy and dos like) and find restore factory settings (or something like that) and click yes.
It's a great feature, and will completely kill any virus or **** problems you have had and couldn't get rid of.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
Oct 01, 2011 | Acer Aspire One PC Notebook
Reset button not working
you will have to press and hold the reset for up to 30 seconds with the power on. sorry if you have tried this but it should work. if it doesnt then there is usually a restore factory setting button somewhere in the setup utility i thing with us robotics you access it by type either 192.168.0.1 or 192.168.1.1 into your internet browser. ok hope that helps. let me know how you go.
Feb 09, 2011 | U.S. Robotics (USR8054) Router
I want to reset it
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Primera Bravo Pro grabs 2 discs frequently
Hi I use to bye verbatim in 50pcs cackebox then there is no problem... when i bye cheep discs and in 100 or 200 spindels i also some times get problems..
Jun 12, 2009 | Primera Technology Primera BravoPro...
Impossible to burn a DVD on a Bravo Discpublisher II
You cannot burn CD's onto DVD's. The sytems is rejecting the discs as its the wrong media format.
Mar 11, 2009 | Primera Technology Bravo (Refurbished)...
Won't output disks to left bin, have tried printer properties without luck
if you are using the Bravo II to burn and or burn and print then you need to turn off the Kiosk mode option in Primo DVD, it has nothing to do with the printer settings unless you are printing only
Nov 05, 2008 | Primera Technology Bravo II DVD Duplicator...
Primera Bravo II
Thanks..piece of cake. A few things to know.
1. The entire robot mechanism does not have to be taken apart, but it has to be taken out in order to get to the screws that hold the drive.
2. Make sure you use the correct holes when installing the drive. If not the robot will not be in the center of the disk when it goes to pick it up.
3. I did it in less than an hour. Drive cost me 22 bucks.
Feb 26, 2008 | Primera Technology Bravo II DVD Duplicator...
Primera Technology Bravo II DVD Duplicator (62743) DVD±R Burner Logo
527 people viewed this question
Top Primera Technology Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Terry Hair
Are you a Primera Technology Computer and Internet Expert? Answer questions, earn points and help others
