Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Frosting up My whirlpool side by side is developing frost and frezing up the evaporator, i have cyled the defrost timer and it remained frosted and the compressor came back on after 40 minutes defrosted evaporator with hair dryer, ran well then frosted agian in 3 days ithink the heater is bad i would like to know where the heater is located where is the heater located. Thanks
    Genius:
  • 1,073 Answers
It is behind the rear cover in the freezer section, you need to remove the freezer shelfs and bins, you will see the screws on the back panel (remove frost from panel) remove the screws and the heater will be a black element that is mounted on the evaperator it will be shaped like a u each end will have a wire connected to it with no power to the machine dissconnect the wires to the heater and with an ohm meter check for resistance if it has resistance then it is good there is a defrost thermastat mounted on the suction line at the top of the evamerator with it still cold and frozen with the meter check this thermastat it should read resistance
if either of these two parts shoul no resistance the one that does not is bad
if both show resistance then the defrost timer is the problem
Posted on May 02, 2008
I have Whirlpool fridge FF450 Elite. Though the fridge cooling is normal, after the night working find in the early morning all magic light flickering though the fridge compressor is working. The freezing...
seems to me by the frost that the inside fan is not blowing air across the cooling radiator (evaporator), due to ice build up impeding air flow or the fan motor stalls or not working a t all. Defrost timer should also be checked if the air flows thru inside the fridge.
Jan 06, 2015 | Whirlpool Refrigerators
Kenmore side by side Model 106.59562990, is frosting in freezer side,
If you are getting frost that is gasket issue your refrigerator is made by whirlpool you can find one using your model number
Nov 06, 2013 | Kenmore Refrigerators
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Evaporator frosting over
defrost system not working..
Defrost system consitst of : heater, Limiter, and a timer ((( Timer can be built on a control board or a mecanical )))
Also your evaporator fan not working can cause frost at the top of the evaporator.
Sep 05, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Frost free freezer keeps frsoting up. It's a french door refrigerator with the freezer on the bottom. The vent is not blocked. The door has not been opened frequently. The appliance is only 9 months...
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Also note that
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up......
Hope this helps
Jul 28, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Food defrosted in top of upright freezer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost thermostat, heaters, or trimmer
Hope this helpout and Good luck
Jul 28, 2010 | LG LRTP1231W Top Freezer Refrigerator
What turns on the evaporator fan? I have a 5 year old GE profile bottom freezer fridge. I have discovered that the defrost timer is faulty. The defrost heater works and the evaporator coils frost up ok...
The main control board is probably the problem . Part number WR55X10656 . This board controls the operation of the fan motors and everything else on the refrig . This is also the " defrost timer " . However , the coils frosting up , is probably because the fan motor is not pulling air across them . Not because of a faulty " defrost timer " . This board is located on the back of the refrig , behind an 8"X10" panel . Usually a resistor burns out relating to the fan motor operation . Cannot replace the resistor , only the board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is "frosting over...refrig part not cooling????
it sounds like the defrost system is not operating and getting rid of the frost. the common fault is that the defrost heater has gone, or the heater cut out has gone or the defrost timer is faulty. how is the door seal in the area- that can cause frosting with warm air ingress.
Mar 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Frosting
you have a defrosting issue, either a heater defrost thermastat or defrost timer
unless removed the wiring diagram is located in the bottom grill of the frige
May 08, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
100 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
