Home | Sharp | AR-5320 Black and White Copier | Need drivers.
Sharp AR-5320 Black and White Copier
Problem for Sharp AR-5320 Black and White Copier
Need drivers.
By Allohh on May 02, 2008
I need to get drivers for the printer.I have a new machine and i want to configure it to use the printer.It has XP as the operating system.Kindly assist now,cause i have some bulky work i want to print for my boss.
Regards,
Same Problem
Jul 16, 2008
-   I need drivers for printing school documents
-   mollo p don
Best Solution
posted on Jun 20, 2008
Very Helpful)
lbcoaster
Rank: Guru  Sharp Expert
Rating: 93%, 152 votes
If you go here:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
You can download the driver for that machine, use the ar 5316 driver.
Hope that helps...
Was this helpful?
Yes
No
Popular Solutions for Sharp AR-5320 Black and White
Questions and Unsolved Problems for Sharp AR-5320 Black and White
Do you recommend Sharp AR-5320 Black and White Copier?
Answer
Answer
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have... (More)
Answer
sharp arm350-450 the imagistics versions adjusting of the printer void area lead & trail edge... (More)
Answer
SIr, I have the SHARP AR 5320E photocopier. How can i set the password to avoid the unauthorised... (More)
Answer
powersuply sharp ar-5320 14c471
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AR-5320 Black and White...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
