Question about Kirby G5 Bagged Upright Vacuum
Attaching the Belt
I am having a problem attaching the belt on the G5. I was given the vaccum and I do not have a user manual. Can anyone help? It almost looks like the hook is reversed and it won't catch the belt the correct way????
Thanks... Confused!!!!
(Leslie)
Leslie,
Rotate the square knob on the front of the attachment to the "Belt On" position (green marker). Insert your fingers in the attachment port (the round opening on the back where the "hook" is) and position the belt so it's centered and as high up as it will go (that's usually just below the center of the opening. THEN rotate the square knob on the front to the "Belt Off" position. You should feel the belt tighten up and the know harder to rotate.
TJ
Posted on May 02, 2008
  • TJ May 02, 2008
    Whoops, I meant "knob" harder to rotate, not "know"
I have a Kirby G5 Vac Cl, the motor will not run. I checked the ac voltage into the vaccum and is o.k. What is it?
I have the same problem with our G5. I check the cord and it's good. Changed the switch, but that actually wasn't the problem. I've tracked my issue down to the motor brushes. When is does run, sometimes blue sparks are seen on the right-side of the motor near the right set of brushes.
I was able to rotate the motor spindle simply by turning the front attachment belt lever (the thing on the front to take off the vacuum head). This rotates the motor just enough to get better contact with the motor brushes.
I'm next going to replace the brushes and see if that fixes my g5. Good luck.
May 01, 2010 | Kirby G5 Bagged Upright Vacuum
I bought this second hand, so have no manual for parts, etc. I smelled something really bad, am assuming it was the belt. How do i release the head of the vaccume to get to the roller. It needs cleaned...
rotate the front belt lifter from green to red then rotate the locking knob above the nozzle. and the head will lift off. it helps if you put the height adjustment in the highest setting. did it smell like rubber burning?
Jan 01, 2010 | Kirby G5 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
Belt
Here is the link to the detailed instructions for belt changing. When you take the brushroll out, make sure that the brushroll spins freely. If it doesn't it will burn up your belts and needs to be replaced.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Marci
Aug 26, 2008 | Kirby G5 Bagged Upright Vacuum
Re-attaching the vacuum
With the nozzle off, turn the big knob until it locks, (will only turn one way) also make sure the belt is in the center, then turn the knob, put the nozzle back on and lock it down. Then turn the knob again and then the belt will be put on the spindle. Next time, before removing the nozzle, turn thast knob until it locks, then remove it, then it will be ready when you want to put it back on.
Jun 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Vaccum
TJ
Apr 29, 2008 | Kirby G5 Bagged Upright Vacuum
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
How do i put a belt on my kirby vaccum
here is a link to a site with step by step instructions for replacing a belt on any G series kirby...it also works for the new model.
Hope this helps! :)
Feb 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 vacuum
Here is a link to the help you need,,,
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Sep 17, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
102 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
