Amana control panel sparks
As my Amana ALW990EAW washer was filling, the control panel began to spark.
  • 58 Answers
Your panel shorted out
replace control panel and wire harness is my recommendation
Although depending on age, these two parts are quite costly the panel alone is 272$ retail
if you decide to buy it you can call amana 866-616-2664
to purchase them, or local dealer normally can sell you the parts
but with a major short like that id recommend replace, if you buy parts bring model, serial, and MFG manufacturing number starting PALW
Posted on May 02, 2008
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
When water fills up it will not agitate
This is a typical problem. What you have is a broken lid switch. This is either located on the door way of the washer or under the control panel. Not a difficult thing to change.
Sep 02, 2010 | Amana ALW480DA Top Load Washer
I have an Amana ARGS7650ww. The igniters will not spark.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
Aug 20, 2010 | Microwave Ovens
I have an amana AKS30E gas cooktop and the ignitors are sparking approximately every 30-seconds on their own. I have checked all the knobs etc and each burner lights fine but with the gas off and ignitors...
I think it's more likely to be a wiring problem, either bad ground or loose connection on the controls of the spark module connector. Look carefully at the switches on the controls to see if they are asking for spark when they're supposed to be off.
Best Regards,
Jun 19, 2010 | Amana AKS3040 Gas Cooktop
The spin cycle is not working on my Amana ALW990EAW. Therefore the water is not draining as well.
Check your lid switch. If this switch is broken the unit will not spin or drain
Oct 30, 2009 | Washing Machines
To replace a washer belt, remove power, remove back panel. On the left side is the motor, clutch, pump and belt. The pump is driven by a coupler clamped to the pump and clutch assembly. Loosen one of these clamps enough to move the coupler away so the old belt can be slipped past the coupler and also to facilitate the new belt to be installed. The belt runs in a pulley built into the top of the clutch assembly and can be "run" onto the transmission pulley very easily. To adjust the belt tension, pull out the washer, tilt it back against the wall......there are 3 nuts and bolts holding the motor assembly to the bottom frame, loosen these nuts off, the holes on the motor bracket are oval shaped so the motor assembly can be moved back and forth. You can move motor to tighten or loosen the belt, just make the belt fairly snug and don't over tighten it.
May 03, 2009 | Amana LWA90A
Washing Machines Logo
Top Washing Machines Experts
