Question about Video Game Consoles & Games
Ps3 trys to start up but keeps reverting to standby
  • 39 Answers
Try a different plug, perhaps its not getting sufficient power? Also, it should still be under warrantee, so you could try contacting sony
Posted on May 02, 2008
My Sony PS3 is the orginal 60 GB unit and worked fine for quite a few years until the icon stopped appearing. This meant I could play blue ray, CD, DVDs. I had no problem playing a game that was on the...
You can try to do a system recovery on your PS3. this will set your PS3 back to factory settings as the settings may have been changed during the use. Here is the process in which you can do a system recovery.'
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
I think you choose option 3 and then repeat and choose option 4. Once you are done with this, try out your PS3.
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
IT TURNS ON BUT THE PICTURE WANT SHOW...
Try the following steps :
Step 1. Turn the PS3 into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear the second beep
Step 3. Wait for the PS3 to start up
What this does is force the video resolution to revert back to standard definition and should hopefully solve your problem
Thanks for using FixYa
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
No video output to television.
HAVE YOU TRIED KEEPING YOUR FINGER ON THE POWER BUTTON FOR LONGER THAN 8 SECONDS,IT RESET THE IMAGE OUT PUT SO IT CAN DETECT ANY NEW OUTPUTS CONNECTED.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
PS3 not showing up on tv no matter what i do
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings.
I use this method to revert from HDMI 1080p to Composite 576p, without having to swap cables and change settings.
My ps3 wont display anything but a black screen through hdmi, tried holding in standby button but only ge t 1 beep before going to standby. i also tried component through av1, that gives a white flash...
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 BUT PLZZZ RATE ME
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
Game trys to load
Alot of people have had this problem, many people say buy a blu ray disk cleaner and it will solve the problem.....but i have found out a better way as i had the same thing happen to my ps3. I phoned up Ps3 support and they told me that i will need to 'restore PS3 system' this worked for me but the problem with it is it takes a while and more annoying it wipes out all your game saves, demos, photos, music and vidoes! so quite annoying, unless you have a external hard drive. If you have that, backup all your ps3 memory onto that before restoring the system. then once its done you can put it back on again.
Jun 12, 2009 | Sony Playstation 3 (PS3) Console
My ps3 started to install a game and said an error had occoured
download the update to a flash drive on your pc then put it in your ps3 and install that way,it may take 2 or 3 trys.
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
Hi when i turn on my ps3 corrupt data comes up on screen and when my ps3 trys to fix the problem it just goes back to the start again i cant even get into the main menu its 2 years old was kept like new i...
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to ONLY option 3 (restore)
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3
9. Follow on screen prompts
Try this and get back with me, I will look into it for you.
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
Tv keeps knocking off to standby mode
It is most likely going to be a defective power supply but there are some other circuits that can cause the problem. I would start by unloading the power supply.
Jan 07, 2009 | Televison & Video
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
