Question about Dryers
Whirlpool Duet Dryer (2yrs old) Light buld died and dryer won't start. We changed bought a new light bulb but the dryer still doesn't start. The computerized buttons still litght up though.
    Scholar:
  • 58 Answers
Sometimes when a bulb goes out or is replaced the unit can short out.
Try holding your end of cycle signal button for 5 seconds, watch the light, if you control lock it, it will light but will not run because control lock is a safety feature.
Also try pushing door in and starting it, might be bad latch
Posted on May 02, 2008
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
I have a Whirlpool Duet Dryer GEW9250 which has all panel lights light but when you push the start button it beeps once and the sensing light is on and it doesn't start. I changed the Thermal fuse...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Dryers
My whirlpool dryer duet doesn't power on. The only thing that is on, is the light bulb inside the dryer when the door is open.
heatman101
Jun 13, 2011 | Dryers
Our Whirlpool Duet electric dryer's inside light quit working soon after we purchased it (almost three years ago). We replaced the bulb but still no light. At the time, it wasn't worth messing with but it...
POSSIBLY BAD DOOR SWITCH OR AT LEAST THE PART OF IT THAT TURNS LIGHT ON AND OFF. IT SHOULD BE A 3 BLADE SWITCH 1 ON ONE END AND 2 ON OTHER OR YOU HAVE NOT SCREWED BULB IN FAR ENOUGH. i HAD TO CHANGE MY BULB TOO WHEN NEW ONE INSTALLED I DIDN'T TURN IT FAR ENOUGH IT WAS STIFF GETTING IT IN.
Apr 08, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
My dryer did the same thing, all the lights worked on front, but the bulb was out inside. All I had to do was to replace the thermal fuse and replace the bulb if you want light. The bulb don't have to work in order to dry clothes
Jan 03, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
116 people viewed this question
Top Dryers Experts
