I own a Technics H?F? system and have a problem w?th the amplifier which appears to have overheated and blown out.I am told that it is a balanced setup and will need all component units supplied for repa?r. However, I live ?n Dalaman in Turkey, and am unable to find a su?table service repair agent. Can anyone help please?
  • 4,234 Answers
What is the model number? With that I should be able to give you the most likely defective parts.
Dan
Posted on May 02, 2008
Technics sa-dx 950 Intermittent F70 Error
There should be removable access panels under the amplifier IC's that are attached to the heatsink. Remove these panels and inspect the solder connections on the IC's and the voltage regulators that should be mounted next to them. These have always had a tendency to go bad on Technics receivers. If you resolder all of these, you should clear up your problem.
Feb 26, 2015 | Technics Audio Players & Recorders
Technics SU-X302 Problems
Greetings
Is there any indicator on or its all off?
anyway i will assume that there is none
1.check power fuse if blown.
2.check power transformer if there is any output voltage
3.check internal fuses
more information will give a better idea.
try these steps and hope this helps.
Dec 25, 2013 | Technics Audio Players & Recorders
Technics sech730
I think it's the power amplifier. Try contacting Technics directly for the parts. Ask for the parts number from the repair shop you had it serviced at.
Oct 30, 2013 | Computers & Internet
Technics SUV-10X. I am looking for the Balance Knob
It is an amplifier, not a turntable.
Have you asked Technics?
Jan 18, 2013 | Technics Audio Players & Recorders
I have a 1990 Technics SA-GX300 receiver that powers on, can be controlled with the remote, but produces no output from any of the input sources. I have been using it as an amplifier for a Zone 2 Bose
27+ is really quite old for electronics, a number of things could have gone but from your description i'm tempted to say the output chips have overheated or blown.... other things to consider with aged audio is the electrolytic capacitors drying out and also causing problems in the audio chain.
Nov 16, 2017 | Technics Audio Players & Recorders
It doesn't want to work anymore!! There appears to be no power to the Disc Player, Cassette Deck or the Sound Processor? The Amplifier screen displays F61 Hope you can be of assistance Thank you
With my crystal ball I can see its a Technics 4 part Hifi micro system you have although the image is just too fuzzy for me to tell which model.!
Joking apart...Your power amp module has a blown channel. These are specific Technics modules and some for the 3/4/5 channel units are quite expensive UK £40-80 just for the module + fitting costs
No DIY fix I'm afraid
Sep 04, 2010 | Audio Players & Recorders
Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
59 people viewed this question
 Grubhead
Grubhead
