I was supplied a Lexmanr Z22 - It starts to print and then stops at about 1/4 page. Doesn't fwd out of the printer just stops. No book available - I thought perhaps a series of "hit the buttons " controls this. I did unplug take the system down and back up. Same problem. The black ink cart. was replaced. It is new.
It´s probably a configuration problem , ralated with the parallel port settings. Tell me what Operating System are you using.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Printer suddenly stops prionting after only one line of text, doesn't feed out. Tried everything on the help menu ; nothing works.
Run Windows XP SP2. I have same problem : printer tops printing after one line of text, paper doersn't feed.
I have run through every step on the help menu, nothing works
