Question about Kirby Ultimate G Bagged Upright Vacuum
Accessory lock is stripped, need a new one? not sure how to fix this prob.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=564785
Accessory lock
Posted by goulds5 on May 02, 2008
Accessory lock is stripped, need a new one? Not sure how to fix this prob.
It will be one or the other , I think you can replace the accessory lock but if I remember right you may have to replace the entire bell housing and assembly.
Listed below are the links you need for the contacting the Kirby factory or manufacturer.
Also, feel free to contact your local vac dealer is you have further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
For a owner manual contact the Kirby Factory Dealer.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 06, 2008
My reset button on the dc24 will not reset, is this a fixable problem?
1.u have a short preventing a reset.
2. reset button is bad.
3. yes it can b fixed but depends on how much trouble u need to go though to fix it compared to buying a new one.
4. dyson is a good brand name, i would check all areas of movement for a short.
Jan 01, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
My microwave appears to work in all aspects except the important one, it is not heating. It is 7 years old. Is this repairable or does it need replaced?
probably a blown fuse. i would not suggest fixing yourself as there are extremely dangerous voltages inside. to have service shop fix would cost 80 to 100,m prob best to toss and buy new.
Oct 18, 2010 | Vacuums
I can't keep the attachments from falling off while in use. I suspect I need new hardware, but cannot find instruction for Fein msx 636 II
Are you fully opening the lock lever when you are putting the attachments on? If you are new to the machine, you need to fully open the locking lever on top, insert the attachment and be sure it "seats" in the shaft holder and then close the locking lever and be sure it is tight.
Sep 14, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Disassemble hoover f5914-900
yes if you strip down the caseing, you need to find out if it has swallowed something in the turbine or if the brush has failed on the rotor inside the caseing, but it should all be fixable
Jan 06, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Cord Heats Up
You have prob run over the cord and caused a internal short in the cord to be sure plug in but dont turn on the vac see if it gets hot if no then your motor is drawing to much power. check the brush see if it moves easly with your hand and UNPLUGED if it does not turn easly there is string or carpet that needs to be removed.And if thats not it look for a new vac
Jun 13, 2009 | Vacuums
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Kirby G4 Bagged Upright Vacuum When in upright position it automatically switches off.
make sure that everything is latched and closed, also make sure it is even on the floor (also "lock" anything that needs to be-i had the same prob, so many things to check!)
May 17, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby ultimate G .accessory lock is striped. Can that be replaced?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=559479
Kirby ultimate G .accessory lock is striped. Can...
Posted by goulds5 on Apr 30, 2008
Kirby ultimate G My belt broke & sucked into my sweeper & got stuck. My husband had to take it a part, he go out the belt but the accessory lock now is striped. Can that be replaced? Have you ever heard of this?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Yes, the accessory lock can be replaced but it may be part of the actual vacuum head of which could be expensive, it may be molded onto the vacuum head and would be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I Need a Wire Diagram for my Oreck XL3600HH!!!
I emailed that diagram to you, hope it helps.
Apr 14, 2008 | Vacuums
Attachment probs
Hi- Do you have a manual for the vacuum? My manual says to raise the headlight hood and then flip out the l-shaped handle on the belt lifter and turn it until the red arrows line up. Turn the accessory lock all the way to the left and the front should lift off. Then take the attachment hose and hook the two hooks over the bar and then push the hose up against the vacuum and lock into place by turning lever to the right. Does this help? Its kinda hard to explain without the pics.
May 19, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
57 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
