Question about HP OfficeJet 7410 All-In-One InkJet Printer
Need more help
Thank you for your help. I did find that the circuit board has a hole in it. You said to fix it - how do I do that???
Helen
  • 1 more comment
  • kdboca Nov 07, 2008
    I had the same problem. A chat with HP told me I had the upgrade option for 269.99 or the repair option for 359.99 but I didnt like that. Saw your posting of serial numbers and chatted with HP again cuz my printer matches these serial numbers. I have a new 7410 on its way becuz of your posting. I suspect the incentives to sell for these tech support agents sometimes gets in the way of solving our problems (I'm being kind! I hate being screwed over so someone else can make a buck.).
  • dmotley37 Dec 05, 2008
    yes my 7410 has a hole in the circuit board also an also would like a fix or a part or where to get a part. thanks very much. any help would be great
    thanks wes
  • albialc123 May 20, 2009
    I have same problem on Office Jet 7210 All-In-One. X Spring in Print Cartridge Carriage is broken (does not stay in place)!
    Problem Solver:
  • 10 Answers
Helen,
HP has extended the warranty for some of these printers like the 7410. It's worth giving them a call. They just replaced mine without charge.
Have your serial number ready when you call HP. (800) 474-6836
Tell them you have a "broken carriage shute and print cartridge rejection".
Hope that helps.
Posted on May 06, 2008
I have the same issue with a broken carriage shute and so called HP. I was told the extended warranty does not apply to all 7410 but only ones with certain serial numbers. My serial numbers did not match their instructions and so my unit is not covered even though it is a 7410. Repairing would cost $360, which of course is basically the cost of a new printer.
Makes no sense to me but anyway, I asked the tech person to send me the specs regarding which serial numbers are covered and here is what he sent:
Locate the serial number on the printer. Through December 31, 2008, if the third and fourth digit of the serial number is 55, 56, 57, 58, 59, 5A, 5B, 5C, 61, 62, 62, 64, 65, 66, 67, 68, 69, or 6A, you will receive a replacement unit and free Extended Support and Service Warranty.
    If the printer is no longer under warranty and the third and fourth digits of the serial number are not listed above, the printer requires service.
Posted on May 07, 2008
When I turn the rcx400 scope on (from park position) it will rotate in the R.A. direction (as it should), "but" if the ambient temp is (approx.) below 50 deg F, when it has stopped it will not move in the...
Could be either-- problem. Check for a cable not fully seated on the circuit board. If it is not a loose cable then the board will need to be repaired by Meade or someone who does electronic circuit repairs.
Oct 05, 2010 | Meade RCX400 12 Telescope
Fader knob is shorting out! Looking for a way to fix the knob from the circuit board? any help would greatly be apprectiated
it is not a short.the knob goes to a variable resistor that has a graphite track and a wiper arm inside it.there are two kinds ,sealed and open.the open have a small hole at the back and you can spray contact cleaner in the hole and it will fix it.
if it is a sealed type,you have to spray in at the circuit board where the pins go in. not the solder side of the pc board, but the component side.
there is a slot on the bottom where the pins come out.
if contact cleaner does not do it,there is probably a crack in the track,and you need to replace the potentiometer.if it says 10k it is 10000 ohms.if it says 100k it is 100000 ohms. if you take it all apart,an electronics shop will solder in a new "pot" for you for a reasonable amount
May 23, 2009 | SPL Dynamics Car Audio & Video
Revlon 1875 Ion Select hair dryer warranty
After Contacting Revlon directly:
They asked me to call:
800 487 7273
Helen of Troy
They said to mail the item back with a short letter and it would be replaced in 2-3 weeks. Nothing else need.
Helen of Troy
1 Helen of Troy
El Paso, TX 79912
Jan 31, 2009 | Health & Beauty
7310 office jet all in one - black ink problem
You are right about the "extended paper clip".
Here's what I found when this happend on my two 7410's. Take a look at where the ink cartridge slides into it's holder. Shine a flashlight on the circuit board at the rear. You will no doubt find it has a puncture in it that breaks the little tracer wires on the board. The culpret is the tension spring arm. It likely has come off it's base support and when that happens, and you install a new cartridge, the cartridge will push the tip of the tension wire g right into the circuit board. After you fix the circuit board, apply some silicone glue to the spring base mount to hold it in place. I hope I can find the part and remove and replace it easily. That I haven't done yet.
Mar 31, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Trouble with key board
HI,i had the same problem and it work!! thanx a looooot!!
Feb 27, 2008 | HP Pavilion dv6000z Notebook
Roger Beep
Hi Helen,
On most Motorola radios, to remove the roger beep, while powered on, you need to press the menu button until the Roger Beep indicator in the display starts to flash. Press on the + or - to change status. Press on the PTT to save and exit.
Hope this be of some help. Pls post back if it worked or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Motorola TalkAbout T6530R (14 Channels)...
Color Problem on SD-643HD5 (Green is not working)
I had a similar problem with my Green CRT. Fixed it by carefully touching up some solder connections.
1) Locate the Green CRT Driver Board mounted on the bottom of the Green CRT.
2) Locate the two large heatsinks on the driver board. Each has a transistor attached to it.
3) Carefully touchup the solder connections on each transistor. I added some additional solder to help reflow the solder onto the pad of the circuit board. It's a bit tricky because the solder has to fill a large gap between the small leads of the transistor and large holes in the circuit board.
Apr 23, 2007 | Pioneer SD-643HD5 64" Rear Projection...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
204 people viewed this question
Ben Johnson
