Hi if when you put the hazzard lights on all the indicators work then this suggests the problem is with the indicator switch, you may need to get it replaced, it could be that it has got corroded due to rain or damp getting in, if the hazzords are working ok then you know the fuse and bulbs are good so all thats left that could be wrong is the switch that works the indicators.
this will need removing and replacing to solve your problem
I had exactly the same problem with my Celebrity XL8, and have noticed others with the same scooter and the same problem.
Rob suggested the same as Paul has. I unscrewed the tiller head and as soon as I moved the wiring the indicator worked again, but that switch does seem to be "reluctant" I'm assuming damp and lack of use, and so will try using it a lot over the next few days and see if that helps. Thanks to Rob and Paul !
Pressing the left indicator button, indicators for that side start flashing but will not stop until key is turned off. All other functions of indicators work fine. Any ideas?
Right side indicator wouldn't work when pressing pushbutton. Took button apart and found rusty. Reassembled button and found indicator now working. Also cleaned up left indicator pushbutton. Problem is this- pressing pushbutton to turn right, indicator flashes several times and then times off. Pressing left indicator pushbutton, indicator flashes but does not time off but continues flashing. It can be stopped by either turning off the key or turning on and off the hazard lights. Pressing the hazard lights switch, the hazards work normally so why does the left hand indicators not time out on their own. Is it a faulty electronic console pcb assembly? Checked wiring all seems good.
