Question about Dryers
I have a 4 prong power cord coming out of my Kenmore dryer and I have a 3 prong power outlet in my wall. Can I replace the 4 prong cord with a 3 prong cord, and if so, how?
  • Hyun Primus May 17, 2008
    I'm trying to buy a new used dryer as mine is kaput.  BUT I live in an older home that has only 3 prongs but the dryer that I'm trying to get is 4 prong  Don't really know what to do or if it worth me buying this dryer.
  • Raymond Cardona
    Raymond Cardona May 11, 2010
    model number please, the reason i ask some do some dont, also you will want to check with local codes, some require certain plugs due to grounding
Purchase a 3 prong cord at a home improvement center. and replace your 4 prong cord. all you need is a screwdriver.
Posted on May 02, 2008
My four prong plug Kenmore dryer is different than my four prong wall outlet. How should I correct this
What you will have to do is buy th correct cord for you outlet. Most homeimprovement stores stock the or appliance store. Get the correct cord for your outlet and replace it on the dryer and it should plugg-in. These are pretty simple to replace with an sdjustable wrench and a screwdriver.
Jan 28, 2010 | Dryers
I have a dryer that has a 3 prong cord however the connection at the wall is a 4 prong outlet. I need to know how to change it.
The following link explains how to convert a 3-prong power cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (White) and the Ground (Green or Bare Copper) wires are terminated at the terminal block. In a 4 -wire configuration these wires are independent of each other. In other words, neutral does NOT get grounded.
If you have any questions, please let me know. I hope this helps you.
Oct 06, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer surface gets extremely hot when
Classic of a clogged vent to the outside, Air out back of dryer should be same outside. Dryer will get hot and take to long to dry clothes with a clogged vent. Pls leave a FIXYA rating.
Aug 24, 2009 | Kenmore 63942 Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
I hope this helps you. Let me know if you still have questions.
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
373 people viewed this question
Top Dryers Experts
