Have an Epson Stylus DX5000 all-in-one printer/scanner/photocopier. Print quality has become very bad with lots of horizontal white bands. Have run the head-cleaning 7 times now (using masses of ink)& replaced all the ink cartridges & changed the paper but it is still exactly the same. Any ideas would be much appreciated. Thanks Helen
    Scholar:
  • 60 Answers
For starters, don't run any more head cleans - too many can cause problems as well as waste lots of ink. Get some Windex (glass cleaner) or if not sold in your area, get a 5% solution iof Ammonia (sold in many countries as latest Cillit Bang - also, like here is Spain, as Viakal) Get the printhead (containing the cartridges) into the Change Cartridge position. Then remove power supply - meaning remove lead or unplug - DO NOT simply switch printer off. Make a two or 4 layer (of linen - like sheeting) pad, about 4" long and around 2" wide after folding. Soak with the Ammonia solution. Slide under the printhead. Reason for removing power supply is when that is done, you can slide head side to side easily. Leave pad under the printhead for at least an hour. Remove the pad. Reconnect the power and switch on. Printer will now perform a clean and should set up ready to print as normal.. Try a nozzle check - you go into Control Panel on computer, double-click on the Printer icon, then select printer, right click and select properties. Check through settings tabbed pages until you find Print Test Page first and try that. Otherwise, go to the settings page and find the Maintenance Tabbed page, where you can select the Head Cleaning and Nozzle Check facilities. Hope full the nozzle check will show a full printout. If unlucky, just repeat the pad routine - and perhaps leave overnight.
Posted on Jun 05, 2009
  • 61 Answers
If you left your printer without use fos two weeks or more, the print head have stuffiness. Yu will have to use an authorized service to fix or replace it.
Posted on May 02, 2008
My Epson DX5000 printer flatly refuses to print.I have it online & ready,have even replaced the ink cartridges,tried all trouble shooting tips I can find....but nothing.Any ideas ?
Try installing the latest Epson printer driver.
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
May 16, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Horizontal bands when printing in black and white Blue comes out red when printing in colour
there should be an option to align the cartridges (it will automatically print a test page, which you then place in the scanner and follow its instructions). Also check your connections--a bad communication between the computer and printer could conceivably make it do some wonky things like that.
Mar 21, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer does not print good copy after doing several head cleaning operations and having enough ink in cartridges.
If the print has horizontal lines of 'missing print' do three head cleqans don't move the printer or switch it off, now leave it overnight - letting the head soak in fresh ink- in the morning, do one more head clean and then print the nozzle check.If it's poor photocopying it is most probably because the print quality for photocopy is set to a low setting. The manual will explain how to change photocopy print quality. Hope this helps
Feb 20, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
My epson stylus SX200 2C will not print black , i have replaced the ink 3 times and cleaned it - it has a lot of gaps and sometine doesn't print black at all. Colour is fine. Help please .
I have excatly the same problem. I have cleaned the nozzles mutiple times and replaced the blck cartridge twice but I still have patchy printing in the black portion of the test print and horizontal banding in word documents
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My Epson Stylus DX5000 won't work. All the lights are flashing and my comouter tells me to open it up and remove the "foreign" object. I can't see any foreign object and can't see hoe t open it up other...
i had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Feb 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Horizontal banding on prints
try aligning the print heads before cleaning them
Oct 10, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson R265 Printer
2. TRASH and REINSTALL the drivers
3. Try a different application and file
4using a PHOTO PRINTER (Stylus PHOTO) try to set the QUALITY OPTION to BEST PHOTO or PHOTO RPM
5. Go to PRINTING PREFERENCES and hit ADVANCE
6. Choose the right PAPER TYPE, SIZE and SOURCE then disable HIGH SPEED
7. Once all those are set choose PHOTO RPM under the COLOR MANAGEMENT box and try printing
8. This will print a lot slower but will be using alot of ink and eliminate the lines
Apr 04, 2008 | Epson Stylus R265 InkJet Photo Printer
1,145 people viewed this question
jasbo
jasbo
