Question about HP Officejet 5610 All-In-One InkJet Printer
Error0xd05d010d error 0xd05d010d
  • kaba abdou May 06, 2008
    my problem is error0xd05d010d reset power
    Novelist:
  • 79 Answers
as this error seems to be the issue with the printers firmware you might need to replace the unit however u can try the following steps
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
Allow the all-in-one to re-initialize. This may take a minute or two.
8
If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
In order to replace the printer call HP Tech support at 1-800-474-6836
thanx
Posted on Jun 04, 2008
Mi impresora HP 5610 tiene encendidas todas las luces marca un errror 0xd05d010d RESET POWER, que puedo hacer.. gracias
SOLUCION: Hola la solucion para la HP Officejet 5610 con ERROR 0xd05d010d es muy sencilla hay que resetear el Equipo lo cual se hace asi:
1. Desconectas el cable que va de la impresora al equipo
2. Luego desconectas el cable de poder de la impresora
3. Mantienes presionadas las teclas (ASTERISCO) * y (NUMERO) # y conectas el cable de poder a la vez.
4. Te sale unas preguntas de Idioma y pais las respondes y LISTO
BUENA SUERTE
Aug 23, 2011 | HP Officejet 5610 All-In-One InkJet...
Error code 0XD05D010D
Error: 0XD05D010D Reset Power.this error coming .pls given the solution
Feb 23, 2010 | HP Officejet 5610 All-In-One InkJet...
Error 0xd05d010d
its hardware issue, you need to service your printer
Jan 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Error 0xd05d010d
Hi
This error code indicate that the product has an internal error condition. You need to Reset your Printer:
Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example) 642b444.gif
  1. Remove the cartridges from the product.
  2. Wait for the ' Insert Cartridges ' message to display on the control panel.
  3. Disconnect the power cord from the back of the product.
  4. Wait 60 seconds.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  6. Reinsert the cartridges, and then close any open doors on the product.
  7. If you receive a prompt to print a calibration page, do so.
  8. Reconnect the USB cable to the rear of the product, and then try printing again.
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
May 26, 2009 | HP Officejet 5610 All-In-One InkJet...
FOR HP 5610 All in One error 0xd05d010d Reset power.
0x errors mean that the printer has an internal error within the firmware of the printer. There are not many steps to try except for a reset. This is a document from hp that you can use to do the reset and hopefully it will clear the error.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en
Jan 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Error code 0xd05d010d reset power
Unplug the power cord from the All-In-One as well as the power outlet.
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Sep 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Error problems
Sir i have my problem with my printer about Hp 5610..
This error appear : Error 0xD05D010D
kindly give me idea please... please sent my email add:ceasarchiong29@yahoo.com.ph
Aug 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Reset Power Error 0xd05d010d
First power cycle the printer and then reset the printer.
May 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Error 0xd05d010d on hp 5610
UNPLUG PRINTER FROM WALL SOCKET PRESS # AND 9 AS YOU PLUG PRINTER BACK IN TO DO A FULL RESET
Jan 18, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
415 people viewed this question
Seeker5211
Seeker5211
