Question about Refrigerators
The freezer will not get cold, i replaced the defrost timer and the t-stat inside the freezer, and it keeps icing up, the heating element does work, the unit is only 2 years old
    Scholar:
  • 58 Answers
Turning it down a 1/2 to 1 knotch id try, the Whirlpool recommended is 0-5 degrees in freezer, im sure you have already cleaned coils.
So my last recommendation is the door. Ensure is closing and sealing. Sometimes the hinges wear out and the door sags, seals but sags causing humidity to get in and freeze up.
Try slipping a piece of paper between seal and door, if it goes right in its sagging, just make sure you check the whole area this way.
Posted on May 02, 2008
Have a freezer on bottom fridge that keeps freezing where the fan is
defrost not working check defrost t-stat, timer, or heating element.
find timer and rotate till compressor turns off; defrost should start and melt ice, if no melting then check defrost t-stat ( round disc located nead heating coil) if you remove it and jump around it will begin to heat normally. If so then do not leave it jumped!!!!!!!! Replace it and you're done!!!!!!
Oct 24, 2009 | GE Refrigerators
FREEZER SEEMS TO BE WORKING, FRIDGE COMPARTMENT NOT KEEPING COLD
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer freezes, freg doent get cold
Freezer cold but not freezing
The freezer works but no cold air in frigerator in side by side unit.
Aug 14, 2009 | Refrigerators
Freezer is not cold
Aug 13, 2009 | Refrigerators
Water on floor and not cold enough
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model also clean defrost drain
Fridge not cooling
Aug 10, 2009 | Refrigerators
Coils inside freezer keep icing up.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
