I have an Omnitech OT-535BL paper shredder. It got a jam, I cleaned the paper out but it still wont work. It sounds like it is turning on when I plug it back in but it wont go.
This unit can also overheat and automatically shuts down when it does; to be thorough--simply unplug, empty the wastebasket, turn upside down, remove any remaining paper from blades, plug back in, and leave it alone for 30-60 minutes. Try again.
It's not an industrial shredder and has a low daily capacity, designed only for small office use.
Posted on Jul 28, 2008
    Novelist:
    Scholar:
  • 134 Answers
This has happened to me, and it turned out to be a bit of paper in a sensor level/switch. Turn off the power & have a carefull look for a senser or lever under the actual shredder unit. Is the paper basket empty? If you can, take the shredder out & turn it over (power disconnected) and look for a jammed bit of paper.
Posted on May 02, 2008
Omnitech 14 sheet shredder is jammed and won't take paper less than year old tried to call omnitech support and get no answer just recording that they are closed any ideas
Unplug it, open it up and clear the jam, reassemble and give it a try, and try not to shred too many pages at once and make sure that you empty the lower part so it doesn't pick up already shredded material and jam up again.
Jul 22, 2016 | Shredder Office Equipment & Supplies
My Omnitech 12 sheet shredder is barely 6 months old and will not even turn on.
check the warranty period and if within that period take it back for warranty repair or a new one
Dec 20, 2015 | Omnitech 12 Sheet Cross Cut Shredder
Shredder is jammed. Won't work.
If the shredder has power, the sheet detector may be blocked by a scrap of paper. Also, cross cut shredders that are an integral unit are best cleaned by turning them upside down to get access to the mechanism. Finally, if the motor became very hot an internal thermal fuse may have opened in which case the shredder will have to be replaced.
Dec 17, 2014 | Omnitech 12 Sheet Cross Cut Shredder
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Shredder keeps running on auto
Unplug it and check to see if theree is any paper caught in the Start switch. Turn it Off, plug it back in and start in the Reverse mode. Then turn it Off and set the swich for On - shread.
If that doesn't work unplug it and find the start switch trip wire, Toggle it a few times with something thin - don't push too hard. You can also spray the switch the canned air used to clean keyboards. Plug it back n, start it in reverse then move it to shread.
Jun 19, 2014 | Omnitech 18-Sheet Cross-Cut Shredder
Omnitech shredder model ot--exc10a , shredder runs but when insert paper to shred it stops, pull out paper and it runs non stop!
Sounds like there's blockage between rollers and it also jams the sensor so auto function stops working. You will need to clear out as much jammed paper as you can using tweezers. Inspect the centre of the feed opening, there should be sensor which must be clear of blockages and moving freely. So clear any stuck paper with tweezers, in addition you can soak any jammed paper with WD-40 and unit should be good as new. Although if sensor arm is damaged then replacement of such sensor is unavoidable.
Nov 04, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Can not get paper to shred
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 26, 2013 | Omnitech Office Equipment & Supplies
My omnitech shredder OT-NXC8PA stopped working after clearing a paper jam. Seems the machine is running, but not sucking papers.
I think you just fried your gears. The motor is fine, but the gears that connect the motor to the shredding mechanism have had the teeth flattened up. No teeth on the gears = not shredding papers. The gears are made of plastic anyway.
Jun 26, 2011 | Aurora Electronics AS1015CD Cross-Cut...
Computers & Internet Logo
3,706 people viewed this question
David Payne
David Payne
