Question about Raymarine GPS
Raymarine A65 Combo. Sonar has never worked properly since initial install by boat maker. The depth is intermittent when it works at all. Sometimes it works at speed, sometimes at rest. Sometimes in shallow water, sometimes only in deep. We have changed the position of the transducer, even going so far as to send a photo of the transducer placement to the Raymarine representative. He recommended changing the position of the transducer one more time so it would follow the profile of the bottom of the boat (i.e. at about a 20 degree slope off of level, thought this was weird, but it worked for awhile). The only thing that we see wrong is that the plastic lock nut which secures the transducer wire into the bottom of the digital converter box(?) was crushed upon installation. The wire seems secure, but...
4 Suggested Answers
  • 16 Answers
SOURCE: Raymarine A65
When the engine starts, there is a voltage drop as the starters crank, followed by a power surge as the alternators kick in and the voltage comes back up.
Ferrites are only there to prevent RF (Radio Wave) interference from other onboard devices.
You should either:
-add an isolated battery to the boat to service only your electronics. That way it is unaffected by the starters.
-There are several devices on the market like Newmar Power's "Start-Gurad" that automatically switch electronics to backup power during engine start. They work great and the electronics don't skip a beat.
Posted on Dec 28, 2007
SOURCE: A65 Transducer
jmiller,
Sound like your getting turbulence from the hull or your angle is allowing cavitation under the transducer. Look under the hull where the traducer is mounted and look for a part that has no obstruction including saltwater pickups, hull relieves, etc. The other thing to check is to take a strait edge on the bottom of the transducer to ensure the angle is slightly forward than the hull.
Bob
Posted on Dec 27, 2008
  • 111 Answers
SOURCE: raymarine a65 transducer 200kh fine 50kh not reading bottom
Sounds like your transducer either has drifted off frequency (age or been hit) Or your a65 is not able to transmit at that frequency. You should take it to a dealer with a Fish finder simulator and have it checked out before you go through the painstaking grief of a new transducer.
Posted on Jan 22, 2010
How do I get water depths displayed on my C70
You haven't said if you have a DSM fitted ( sonar unit and tranducer) the C70 is only a multifunction display unit MFDU you then put a card in for navigation, a radar aerial/ scanner or a sonar unit for depth and fish finding .
if you have a sonar unit and it's working then
press Presentation
press Depth Digit and select on / off
press OK or cancel to return to the default display
hope this helps
Aug 28, 2014 | Raymarine C70 Multifunction Navigation...
Sonar intermittent very good through hull transducer , sonar works sometimes then will not work rest of day ,
Check the mounting location, check the cord connections, make sure the ducer is actually clicking when it is not working, otherwise either the unit or the ducer is going bad
Jul 29, 2014 | Garmin Gpsmap 441s Dual Frequency Combo...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
Hello! Our Raymarine A65 will not start up. It starts a boot process but does not show "Raymarine A65" on the display and no chart is displayed as it usually does. Regards Odd
Probably a bad printed circuit board, just had to send mine in to have it repaired. When I hit the power button, I did hear a beep, but then nothing displayed. Mine was still under warrenty, so don't know the repair cost if yours is not.
Jul 15, 2009 | Raymarine A65 Combo GPS...
Sonar not working properly, intermittent
Generally, that indicates air bubbles in the water under the transducer. If you have a transom-mount transducer, make sure the bottom surface is level or angled slightly down. If you have a thru-hull, make sure your bottom is fairly clean in that area.
Oct 20, 2008 | Garmin GPSMAP 440 Chartplotter GPS with...
A65 Transducer
jmiller,
Bob
Sep 11, 2008 | Raymarine A65 Combo GPS...
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
RAYMARINE
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Jul 13, 2008 | Raymarine A65 Combo GPS...
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Raymarine A65
You should either:
Nov 16, 2007 | Raymarine A65 Combo GPS...
GPS Logo
49 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
