Question about Lands Phones
I got a G60mtl chinese mobilr phone, The sound has stopped on all applications, ie audio, ring tones and other effects. The speaker is working perfectly for key pad sounds so I know its still working. I have tried reset and change profile s but nothing works can you suggest anything, cheers eoin
  • patrick1881a Oct 25, 2008
    no sound on my phone
Hi i have the A8+(G60MTL) phone and i was wondering if i can download GPS software to my phone or Games.
Posted on Jun 27, 2008
Have u got new software to cect g60mtl or a8 ??
Posted on Sep 11, 2008
I have a Chinese mobile phone and the number for the battery charger is g60mtl - it will not charge- please help
Posted on May 28, 2008
How do I add my own message tone to phone , I have had the tone sent to me via blue tooth but cant work out how to select and add it as message tone . can only find ring tone , alarm tone and caller tone.
Step1: Click on "applications", then select "My files" Create a folder in the root menu and call it "media"
2. Click on media then create another folder and call it "audio"
3. Click on audio to enter then create the final folder and call it "notifiations"
4. When you have done this transfer your message tones to notification folders
5. Go to message,setting,select ring tones and you will see your files
Hope it helps.
Jun 08, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
Audio suddenly stopped working. No music ring tone or anything? can I do anything?
Hi the speaker in your phone could cause the problem if it stop working thats you will not hear any sound you should change the speaker
Jul 10, 2010 | Sony Ericsson Walkman W810i Cellular Phone
The phone doesn't ring, there is no speaker phone, and no tones when you dial or text.
Try using the side keys to adjust the volume. It sounds like the phone is on silent. Go into the audio settings and play around the ring tone, text, dial tone sounds and settings until you feel that it is appropriate for you.
If the phone is still not responding with sounds or tones after you have set the audio settings, the phone might be defective and you may need to have the phone company look at it.
- Neal
Apr 27, 2009 | AT&T LG CU515 Cell Phone - Black
Lost my ring tone
If settings were deleted in error... try this.
Go to PROFILES.
Make sure an audio profile (ie Normal) is selected.
For further personal settings:
Select ADVANCED.
Select (ie) NORMAL.
Scroll to PHONE and depress the pearl ball.
Select OUT OF HOLSTER and set to TONE.
Select RING TONE and select the tone you want.
Select VOLUME and set to your preference.
You might want to do the same for IN HOLSTER.
Apr 23, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
DECT 225 - Ring tone etc. no longer works on 1 phone
Use your screw driver, open the handset, maybe the speaker wire is broken. Or use multimeter to check the dc resistance of speaker. Generally ,it is 8ohm or 4 ohm.
Oct 18, 2008 | Philips DECT 2252S Cordless Phone
MP3 ringtones sound 'funny' on my N73!
ur speaker must be containg dirt or water must have entered in ur speaker if ur cell is in validity period then go to nearest nokia care n tell them ur problem they will solve it surely
Apr 14, 2008 | Nokia N73 Cellular Phone
Ring tones are all distorted
if you having distorted sounds even if you change the ring style and deafault ring tones' the problem is the speaker buzzer of your phone....:D
Apr 09, 2008 | Motorola Mobility RAZR V3
Speaker problem
MT6227 Drivers and pc sync "Chinese Phones" • TOXIGON
https://www.toxigon.com/mt6227-drivers-and-pc-sync-chinese/
Oct 1, 2007 - MASTER PASSWORD 1122Sorry MT6227 FIRMWARE is not available at the moment. ... Please try it and tell me by comments, I don't have my Chinese phone anymore. Drivers for Chinese phones that you can't find elsewhere, like "Cect ..... while i m connecting it with my pc , it showserror unknown driver.
Mar 17, 2017 | Wisecom WS 5614PSL (WS-5614PSL) Modem
No audio from speakers
With other models (I don't know about the 6515) there's a known hardware issue with the switch in the headphone jack sticking, getting bent, or breaking. One discussion at: http://www.ipaqhq.com/forums/showthread.php?t=12999&highlight=sound If the phone ringer is on the same circuit as the rest of audio, then that would not be the explanation. But I can also imagine the ringer being a separate circuit. Good luck.
Sep 12, 2005 | HP iPAQ hw6515 Pocket PC
Lands Phones Logo
436 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
