Question about Dryers
The drum no longer turns - Dryers
    Master:
  • 518 Answers
You didn't provide much info on the machine (like make and model), but odds are either the belt or the motor is the cause.
Hope that helps...
Geno
Posted on May 02, 2008
Stopped in mid-cycle. drum will not turn even by hand, unloaded. Plastic/metal debris in filter.
If you have a front load washer, sounds like you do, by your description. If you can't turn the drum by hand and have foreign object within the pump filter, its time to replace the washer. It sounds like your spindle has cracked and the tub will no longer be suspended from the rear. Metal from the spindle and plastic from the basket (spin drum). Sorry for the bad news but its cheaper to replace the washer than fix the damage. Good Luck
Apr 18, 2016 | Washing Machines
I have a brother 5250dn printer that's on strike right now. At first it wouldn't print indicating a drum problem. We addressed that issue by resetting the drum counter (took out the toner/drum and held...
Try this.... no guarantees but I have seen this work.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jan 19, 2011 | Brother HL 5250DN Laser Printer
We have a Hoover Elecron Dryer De Luxe D6292 and the drum will not turn. There is a loud clang and the belt is no longer on the pulley arms. We have tried replacing the belt, but each time the drum rotates...
here is a picture of some belt diagrams:
http://www.applianceaid.com/images/belt-config.JPG
Now there may be a problem with the drum rollers/glides or idler arm:
rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
idler pulley(third on list right under motor):
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Hope this helped Tim
Jan 09, 2011 | Dryers
My dryer has a high pitch squeal when starting up. It would go away after a few minutes when it warmed up but now the squeal is getting worse and lasting longer
Kevlar 'slip strip' on which the front of the drum runs may need to be replaced. Try turning drum gently by hand to guage whether or not it is turning freely.
Feb 28, 2010 | Dryers
My dryer drum will no longer turn easily...and dryer won't start.
sounds like the motor is going bad,did you remove the top to see if the belt broke or if it jumped the track?mike
Feb 19, 2010 | Kenmore 62802 Electric Dryer
Dryer drum won't turn, though dryer sounds as if it is
Don't run it like this any longer- I'm 99% sure you have a broken drum belt.
Unplug the dryer, take the inspection plate off the back, and see if the skinny little belt is held around the motor pulley apparatus.
The reason you shouldn't run it any more before determining status of the belt, is that the element(s) will burn out when the belt isn't in place.
Dec 15, 2009 | Dryers
Maytag med5740tq0 will heat up but drum does'nt turn
This could incidicate one or more problems. One of which could be that your belt is broken and no longer turns your drum. part number for the belt is 8066065 which is better known as a 341241. this is a common problem and can be replaced by removing the drum. The other possible cause of the drum not turning could be a blown fuse inside your home. This will allow the heater to work but not the motor since they both take 110v. If your fuses are okay, you could also have simply a burned connection. I would visibly inspect these and then have it checked by a technician if they check out.
Thanks
Oct 14, 2009 | Maytag Dryers
Replaced belt still queeking even louder
If it's a really fast squeek, I'd suspect the motor bearings.... a little slower, I'd suspect the drum roller guides (more likely!) Try removing the belt, and turning the drum by hand. The other possibility is the blower fan - you can also tell with the belt removed and the dryer running..... it will be clear if it's the motor or the fan, without the drum turning.
Mar 14, 2009 | Maytag Dryers
Whirlpool Thin Twin Model LT7000XUNO stack unit
ithink I have the lt7000xuno
something got jamed in it now the drum won't turn mabe spun abelt or is there a cut off switch?
Aug 05, 2008 | Whirlpool LTE6234D Top Load Stacked...
My dryer drum is no longer turning when I press start.
When you turn it on, can your still hear the motor running but the drum doesn't spin? If so, yes, the belt could have broken or slipped off the pulley.
With my dryer, putting in a pair of shoes often makes it turn off. I hear it tumble for a while and then and then I hear a squeal and then the dryer turns off.
I have seen a device that can be put inside a dryer and adjusted to fit tight between the diameter of the drum and will allow you to put shoes on it. This solves the CLUMP - CLUMP - CLUMP issue.
If you don't hear the motor, its possible there is a blown fuse. have you checked your breaker panel too?
Good luck,
- Jim
Jul 15, 2008 | Danby DCD5505W Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
