Dell dimension E310 crash
Shuts down after running about 7 or 8 minutes.Black screen, series of beeps(1-3-2), and LED showing #3 and #4 on tower front panel.
Was rebooting and doing same for 4 or 5 times. Now will not reboot.
Still showing 3 and 4 with black screen.
Uninstalled DVD drive when problem started as recommended on error message.
Defragged hard drive also.
  • earthange439 Dec 02, 2008
    turn on black screen no mouse somethimes mouse green led on odd noise moditer working with light but nothing shows
  • Anonymous Mar 21, 2014
    My Dell dimension e521 keeps crashing. Dell confidence test of HD presents errors of 4400 011B, medium error (0-0000)in four message blocks so far (25% completed). I also get messages of Device Initialization Failure 4600:0009. SmBios structure 52 has illegal length. OS: Win 7 Home Premium. The computer runs for a short while then goes to a black screen that asks me to boot from my external DVD, which then runs diagnostics. I am trying to determine whether to replace the hard drive, reinstall the OS or replace the computer. Thanks for any advice or wisdom.
  • 1,183 Answers
Hi ed,
There is a problem with the hardware of the system, In case you have another system to go online , go to the following link
http://tinyurl.com/6khcaf
This would help pin point the problem. What I think is the problem on your system is misaligned memory modules , try reseating them one by one and power on to check change in those front LEDs
Thanks
Mandeep
Posted on May 02, 2008
    Problem Solver:
  • 7 Answers
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
Dimension E310 6 beep
if the beep pattern and led light pattern it's a memory problem, try reseating the RAM. Problem and solution is described multiple times here
Dimension E310 won boot up 6 beeps
21.June.2015
Apr 18, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How do I install a barracuda 7200 into my dell dimension E310
You can visit support.dell.com . They have all resources and even step by step procedure on how to put it back together.
I hope this helps!
Dec 12, 2012 | Dell Dimension E310 PC Desktop
Issues with 2gb 32ddr dell memory compatible in dell gx280
Unfortunately, the CPU on these computers may be capable of handling the 2GB memory, the motherboard isn't on either system.
The specs for the Dell GX280 are available here: http://support.dell.com/support/edocs/systems/opgx280/en/ug/specs02.htm . This system takes 400 or 533 MHz DDR2 non-ECC memory and the form-factor determines the maximum memory. In the mini-tower format, you have 4 DIMM slots and can have 4 GB of memory. In the small form factor, it takes 2 GB max.
The Dell E310 specs are available here: http://support.dell.com/support/edocs/systems/dim3100/en/sm/specs0.htm . This system can only support 2 GB (2 x 1 GB) memory.
I wish that I had better news for you.
(who had a similar Pentium 4 computer with the 1 GB limit. Since that system was running a 32-bit system and only actively addressed 3 GB, I didn't try to put 2 GB sticks in any of the 4 memory slots.)
Aug 30, 2012 | Dell Computers & Internet
Dell e310 get black screen with cursor blinking after dell splash screen. F12 not responsive. front panel shows power green and number 123 are on. Thanks
According to the any brand code correct but some time code are same and problem is differ so change slot and try reboot and go to the BIOS and disable memory module single slot check it only slot me be possible memory slot is not working dot depend on dell support form only try differ
Dec 30, 2010 | Dell Dimension E310 PC Desktop
Dell Dimension E310 won't boot up
this could be your motherboard, but could also be your video or audio card too. try making sure those are seated properly or try replacing one or both, if you so desire.
Jan 18, 2010 | Dell Dimension E310 PC Desktop
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
Blue Screen for Dell Dimension E310
1- Go To My Computer , and Right Click , Choose Properties .
2- Select Hardware , then Device manager , Then System Devices , and Choose CPU To Ati2_bing.gif
3- Update it manualy and Select PCI Bridge .
4 - It will work.
5- If u have any problem E-mail me @ support@rdptechs.net
Dec 15, 2009 | Dell Dimension E310 PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell E310 Dimension that won't go on!
Boot the computer into safe mode. Run full-system anti-virus scans to ensure that the system is virus free and to remove any infections that may be present. Reboot system.
Instructions for booting into safe mode:
1) Start system
2) As system is starting, press F8 key
3) Boot menu will come up asking how you want to boot - choose Safe Mode and press ENTER
4) Your computer will start with limited services, no internet connection, etc. This will allow you to check the system and scan for viruses without interference from non-essential services.
Let us know how it turns out.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | Dell Dimension E310 PC Desktop
Dell Dimension E310 not booting
Unplug Motherboard completely from all power. Remove RAM and all ISA/PCI/PCI-E/AGP cards out carefully and wait like 5 minutes. Try again using only bare essentials: Video card and 1 stick of ram. Alternate RAM is possible if it doesn't work. Try a New Video Card if nothing else works... Most MB manufacturers will have a chart that has the beep codes so you can at least narrow it down if not solve it by the beeps.
Dec 11, 2008 | Dell (E210882) Motherboard
Computers & Internet Logo
908 people viewed this question
David Payne
David Payne
