Question about Cell Phones
Phone suddenly switgched off and will not respond to on button or charger.
Burn it
Posted on Jun 21, 2008
Phone suddenly off and not start
1-
  • Hold the power button down for five seconds or more. This can reset the phone on many models and possibly cause a reboot if the phone has frozen. If that doesn't work, take the battery out of the phone and wait at least 30 seconds. With the power source gone for an extended period of time, any glitches preventing the phone from turning on should be removed. After 30 to 60 seconds, replace the battery and see if the phone turns on.
or t
  • 2-The simplest explanation is that the battery is dead. Grab either a wall or car charger and plug the phone into a power source. Wait at least two minutes before trying to turn it on because if the battery is completely dead, it will need a moment to recharge enough power to turn the phone on. If the phone still does not turn on, then the battery or the charger may be faulty. Borrow someone else's charger and see if an alternate charger can get the battery to respond. Otherwise, you may need to replace the battery in your phone.
or
  • 3-If your phone is computer compatible (like the iPhone), use your computer to reset it through a USB cable. The phone may have come with a computer program when you purchased it. The program goes on your hard drive and will recognize and access your phone when the phone is connected to the computer via the USB cable. The iPhone uses iTunes for this purpose. Once the phone is plugged into the computer, access the program and click the "Restore" button. This can erase contacts, photos, calendars and other data but should restore your phone back to working order. It will also restore any information from the phone that you had previously backed-up on the computer, such as text messages and settings.
Feb 01, 2013 | Google Cell Phones
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Battery power was very low. plugged Drsire into charger and set phone to shut down mode. when i unplugged it from charger and pushed the 'on' button,the phone vibrated 3 times but will not turn on.have...
Please remove the charger and take the battery out of the phone for one minute. Whilst the battery and charger are out press and hold the power button for 10 seconds to drain any residual power from the phone.
Replace the battery and charger and after a minute power up again.
If the issue is resolved or if it persists please do let me know.
Many thanks for using FixYa
Nov 27, 2010 | HTC Desire Cell Phone
ON\OFF buton is not responding. The phone is
The power (On/Off) button is not responding probably because it is broken, the phone is dead, or the battery is dead or drained. Connect the phone to a charger and check whether the phone charges the battery or not. The power button is indeed not responding and broken when the phone charges the battery. The only way to turn on the phone is by replacing the power switch.
When the phone doesn't charge the battery, the phone may be dead or the battery is dead/drained. To revive the battery and verify whether the phone is dead or not, check it here.
Apr 06, 2010 | Nokia 6233 Cellular Phone
New Motorola SLVR is suddenly unresponsive, won't turn on
Try to replace the battery and if the unit is still under warranty advise the store to replace the battery.
Jun 09, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Enter button suddenly NOT responding any more
I am not sure but problem could be in your button problem. Just restart your handset and then check if the problem persists.
Nov 13, 2008 | Nokia N70 Cellular Phone
Power on Problems
Sounds like your battery is dead. Does the phone respond when you plug in the charger? If it does not respond, you may either have damage in the charging port, or a bad charger. If the phone recognizes the charger, shows that it is charging, but still won't work when you unplug it, I would recommend trying a new battery. You should be able to go to a retail store that sells razr's and ask them to try a different battery in the phone to see if it works. If it powers on with the new battery, buy it.
Sep 18, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
