Question about Casio Watches
How to set casio pathfinder alarm to vibrate?
3 Suggested Answers
SOURCE: how to turn the alarm
jjjjj
Posted on Aug 29, 2008
mcdevito75
  • 1970 Answers
SOURCE: I cannot turn off the alarms
mcdevito75 here, Best Bet, look for a small watch repair shop in your area, mechaism could be stuck.
Posted on Jul 01, 2010
Can't get Casio Futurist into vibrate mode since reoplacing the battery. The "VIB" area on the watch won't flash for me to adjust the setting. Am i doing something wrong or simply goin
2 things you could have the back on wrong way or you've lost the small coil spring that touches the back plate of the watch that give you the vibration ,,
Nov 22, 2014 | Casio Futurist Mens Vibrating Alarm Watch...
Set casio pathfinder watch
try this site:
http://www.ehow.com/how_5214673_operate-casio-pathfinder-watch.html
Nov 12, 2014 | Casio Pathfinder PAG80-1V Watch
I just changed the battery on a Casio watch A158W and now the alarm and hourly chime doesn't work.
The replacement battery may not have been installed properly. It can be a tricky operation. Also, the replacement battery could be ng.
May 31, 2013 | Casio Pathfinder PAG40B-2V wristwatch
Replaced batteries in Casio Pathfinder watch. Functions work, but alarm does not sound.
there are two reasons for this while changing the battery the small coil sping that operates the alarm as fell out or you av put the back on in the wrong position
Jan 20, 2013 | Watches
Casio watch LDF10-7A manual
Best Deals Casio Women s Vibration Alarm Watch LDF10-7A Get Perfect If you are looking for news and reviews, Casio Women s Vibration Alarm Watch LDF10-7A The Buyer s Guide.
Jul 26, 2012 | Casio watch style LDF10-7A Watch for Women
I have a casio sport sea pathfinder spf-40 I cannot find my manual and the alarm keeps going off, one at 12 midnight and one at 7.15am and i cant remember how to turn it off please help ? andy
I had this problem with the Casio 2926 at midnight for many weeks and no matter which buttons I pressed, it carried on.
I solved it on my model, by going into alarm set mode (AL) by toggling button on lower left of watch face. Then using button on lower right, cycle through all (5?) alarm options and also check the tiny screen new the rim at top right of watch face marked with SNZ ALM SIG. If a little black box shows up on this screen, switch off the alarm or snooze, by pressing the button on top right.
Otherwise go to Casio and go through their instructions. The watch is not designed for easy use.
Oct 28, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    Jul 01, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Turning off the alarm on the Casio Sea- Pathfindder SPF40T
    Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
    http://world.casio.com/wat/download/en/manual/
    You will need a pdf reader on your pc, you will find all instructions in there.
    Jun 04, 2008 | Casio Sea-Pathfinder SPF40-T Wrist Watch
    Watches Logo
    156 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
