Question about HP PSC 950 All-In-One InkJet Printer
Fax not working
I recently moved and now have a new phone number. I assumed that all I had to do was plug everything in and the fax would work using the new number, but it doesn't. I can't send or receive faxes. I'm trying to find the instruction pages for the manual. The printer component works, so I'm sure I have it hooked up correctly.
  • 53 Answers
Http://www.fixya.com/support/p378856-hp_psc_950_all_in_one_inkjet_printer/manual-3470
heres the manual
Posted on May 02, 2008
Cannot receive a fax but can send faxes with no problems. No diverts etc on the line.
From your phone call the fax number. Watch the printer console. It should give a message that there is an incoming call. Also you should hear the fax noise on your phone. If none of the above happens, plug a phone into the wall jack that your fax is plugged into. Call the number from another phone, if the phone doesn't ring...you have the wrong phone number. If everything above works, you may need the fax card on the formatter replaced.
Sep 23, 2011 | HP LaserJet 2840 All-In-One Printer
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
Can't receive faxes
Hello. Make sure you're plugging the printer to the correct phone jack in the wall. If you're using a splitter, bypass it. Check the settings in the printer. Make sure you assigned the correct Fax number in it and place your Fax name as well. If you're sharing your home phone line with the fax and you have an answering machine, set it to answer first and the Lexmark fax later with a minimum of 2-ring gap. If you have a voicemail, turn it off since it will a conflict with the fax or avail a distinctive ring feature from your phone company so it can work with the fax. Hope this helps.
Mar 23, 2010 | Lexmark X6170 All-In-One InkJet Printer
How fax says File full and will not fax any docs. How do we fix?
First I would plug a regular phone into the phone line to make sure it has a dial tone. Assuming that works send a fax to your cell phone and see if the fax machine dials out and makes your cell ring. Assuming that works check the fax for an error code as to why it is not faxing or failing.
Feb 11, 2010 | Panasonic UF-4000 Printer
Fax issues - Brother 1020e
Sounds like your phone cord is plugged into the "tel" or "phone" port on the back of the fax. It should be plugged into the "line" port.
Oct 25, 2009 | Brother FAX-1020e Plain Paper Thermal...
Fax number/Reset
I did a little troubleshooting--in other words looked for the obvious--such as Menu...then kept on until I saw the number (original) out there--then, just plugged in the new one.
Thanks for answering so quickly!
Jbjhutch
Jul 28, 2008 | HP Officejet 5610 All-In-One InkJet...
How do I get a fax number?
you are correct just use a splitter and if you hear a fax . beep beep then hit answer
or just set your fax to answer on the 6th ring.
or purchase a dedicated phone line for faxes.
who uses faxes any more.
May 12, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Do i need a seperate phone number to fax with
You use the same number for fax but you need contact the telephone to provide the fax to same line.You can call LEXmark to set up printer..
Apr 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
Trouble with the fax function
There is no setting to make this work, sorry.
This is just the nature of digital phone service. Some fax machines will work, and some won't, but generally the extremely high priced units are the one that will work (of course, right?)
It all has to do with the way the fax machine "hears" the ring, or detects the dial tone.
The only other option is to use the HP as a scanner, and send the faxes through the internet using a 3rd party fax program.
I know this is a pain, but unless you want to shell out big bucks for a new fax machine, it may be the only answer.
Apr 07, 2008 | HP OfficeJet k60xi InkJet Printer
Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Jan 21, 2007 | Panasonic Workio DP-2330 Printer
HP PSC 950 All-In-One InkJet Printer Logo
Ben Johnson
