Question about Sharp Microwave Ovens
My convection oven keeps stopping while cooking in convection mode. I have heard of other people having the same issue. is it worth trying to get fixed or just to buy a new one. it's about 3yrs old.
  • 883 Answers
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
Posted on May 28, 2007
  • 4 Answers
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Posted on Dec 11, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 03, 2009
  • 25 Answers
SOURCE: Daewoo WM1010CC convection/ microwave combo unit issues
Likely takes a torx wrench or some other special star tool to open it.
Could be a bad relay a bad mag tube or a bad timmer or a bad door switch. Needs to be trouble shooted. You have to get it open and check the fuses and test the voltage on the pri transformer first.
Posted on Jan 14, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: NNC2000P - Microwave does not work but convection works
An IGBT is an insulated gate bipolar transistor - sort of a hybird between a bipolar transistor and a MOSFET.
These are the final output driver transistors in the high-voltage inverter.
If it stops after 7 seconds, it still has a problem with the inverter.
It's likely a bad transistor, an electrolytic capacitor with an internal short or bad ESR or altered value, bad connection on the inverter board, a shorted diode or blown resistor, or a bad connection in the wiring.
Reputable service centers will have a repair warranty, but it may only be 30-90 days.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You should use a Panasonic-authorized service center so they'll have the service manual and (hopefully) experience and training to repair inverters.
In the US, you can find an authorized Panasonic servicer here.
This sounds like a non-US model. If so, visit panasonic.net, find your home country, then find the service / support links.
Posted on Feb 15, 2009
Can i use aluminium foil in convection mode in microwave
It is best to not use aluminum foil in a Microwave since microwaves cant go through it, so It will not heat properly. If you are using it only on Convection It is just fine, it is like using a regular over then. Same kind of issue though if you are using convection, that is to bathe the meat evenly in circulated air. If you cover it in aluminum you lose a little effectiveness of the convection on the food your cooking. If it is to stop splatter just make a small tent over it and maybe tooth pick it down. Letting the air flow get under it but not splatter the entire inside.
Aug 24, 2017 | Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Microwave plate turner keeps spinning even with door closed and microwave turned off
My microwave is doing this as well; It's a frigidaire model #FGMV154CLFA.
After using the microwave part (it is also convection), the light stays on in the microwave and the turner keeps turning.
And I've only used the convection part of my microwave a couple times and I'm not sure if I was successful. While trying to cook something in convection mode, I pressed convection, then pressed the temp i wanted, then convection, then keyed in the time I wanted the item to cook. The microwave started and the timer started counting down but the countdown stopped with 8 minutes left? I left it alone to see what would happen and it never finished so I restarted the process again.
PS..I've never gotten an error code
Apr 23, 2011 | Microwave Ovens
Small amount of white smoke coming out of kenmore convection microwave in oven mode
That is usually caused by a build up of fat from microwave cooking on the heating element. It will clear under normal conditions and return if one cooks foods like bacon etc, un covered to prevent splashing of the food that is being cooked.
Hope that helps.
Oct 31, 2010 | Kenmore 63793 Convection / Microwave Oven
The microwave will only work for 59 seconds then it stops. It is working but only for 59 seconds. I am not sure about the convection oven was afraid to try it. The unit is in our fifth wheel RV. I can heat...
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Apr 18, 2010 | Sharp R-1870 Convection/Microwave Oven
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
I've just bought a microwave/grill/convection oven combi but the manal isnt very comprehensive. i'm not sure what i can use to cook in with the convection oven function. can i use metal in there? eg. can...
Yes.
In convection mode, you can use anything that's oven safe. Anything you would use in a regular baking oven in other words.
There's a very interesting and helpful article on convection cooking here, and you can find more tips here.
Nov 05, 2008 | Microwave Ovens
Microwave Ovens Logo
133 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
