Question about Refrigerators
Swan fridge hi my fridge has just had new thermostat used to have settings on number 3 but it has frozen on the back before it was dripping wet, it is a swan fridge model sr5040 im fed up of wasting food and now sandwich meat is freezing.
IFIXALL
  • 868 Answers
SOURCE: We have a Whirlpool gb22dk
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Posted on Jun 09, 2008
mikedurland
  • 481 Answers
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
SOURCE: My fridge is too cold
I wrote under "guest" earlier on Aug 5th. I jave since discovered that the problem is a manufacturer problem. Apparently Liebherr had problems with their sensors, which they have since corrected, but they were put in all the earlier fridge/biofresh. I contacted the Liebherr agent in Melbourne Australia where mine came from (Andi-Co), and they have sent someone out to replace the sensor free of charge (mine has been out of warranty since March 2008). The sensor tells the compressor when to shut off, and when faulty does not do this so the compressor keeps running and freezes everything. I did have to make a bit of a fuss though and write them a letter before they came out. I printed out this page as evidence that it was clearly a manufacturing problem, which they have now confirmed. So I suggest you ask your supplier to fix the problem free of charge. Good Luck!
Posted on Aug 14, 2008
docjohn174
  • 943 Answers
SOURCE: freezing problem
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
Why water under crisper ..Frigidaire top freezer
You have a frozen or stopped up condensation drain line. Disassemble freezer to access evap coil and defrost ice in drip pan and drain line. You probably should replace the thermostat(cold control) if it hadn't been set to the coldest setting or if the fridge hadn't been opened for a long period of time prior to this problem. If the drip pan and drain aren't frozen then blow out the drain line with hi pressure air
Jul 23, 2015 | Refrigerators
I have a 3.3 fridge/freezer-the back wall of the fridge has a buildup of ice ???
Sounds like either: 1) The thermostat is set too low.
2) The defrost control is bad
3) The main drain in the freezer has frozen over not allowing water to drain.
Jan 29, 2013 | Haier HNDE03VS 3.3 Cu. Ft. 2 Door...
Hi my freezer is not keeping food frozen it starts to thaw after a few days i have cleaned the back of the fridge it is not up against a wall the door seal seems okay the compressor works as i can hear it...
the defrost heater or thermostat on the evaporator coil is bad,you can tell if the inside rear wall of the freezer is covered with frost,you need to remove this panel after defrosting with a hair dryer and find which part is bad
May 19, 2011 | Refrigerators
The freezer (top) works fine but water leaking in the fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 31, 2010 | Refrigerators
Why is our fridge frozen all the time?
Hi!!
The evaporator fan (little fan in freezer), is the one that blows cool air to the fridge. If your evaporator is freezing up, it could be due to the thermostat set too high, and the fridge control set too low. Set freezer temp. one number lower, wait 24 hrs and check, if evaporator still freezes, lower it one more setting. If temp in fridge is OK. leave it alone, or adjust accordingly.
Let me know how it worked out.
Good Luck!!
Mar 28, 2010 | GE GSS25JFM Side by Side Refrigerator
Fridge Icing up on N1B Candy frost free fridge freezer
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 02, 2009 | Refrigerators
Water dripping down from back of fridge.top shelf very wet and bottom soaked
hi there......can you check (1) the vent hole at rear of fridge is clear to allow condensed water to flow out...(2) that your thermostat is turned up to 3or 4....(3) check that your fridge is set up properly ..that is it is tilted back slightly...
regards Sir Galahad
Aug 21, 2009 | Refrigerators
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Ice & water dripping in refrigerator
hi , roger here i am a maintenance tech for an apartment complex that just happens to have whirlpool appliances. the way i see it is the most likely problem you have is a clogged drain. if you push the refrigerator out where you can access the back of it you will see a plastic hose that runs from about the middle of the fridge down to the bottom and then dumps into a pan that sits on the top of the compresser. the easiest thing to do is to remove the hose from the pan and blow hard through it or hook an air nozzle from a compresser and blow through it . it should take care of it. also try to avoid turning the fridge up on its max settings. hope this helps.
Feb 13, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
