Question about Dishwashers
Whirlpool APDW/1 when i try to turn it on it doesnt start ,it just keeps beeping at me and the start light just keeps flashing .. what can i do?
  • 2 more comments
  • kenhan Jun 23, 2008
    I have the same problem, Doesn't matter what I set the program to when I close the door the machine starts beeping, when I open the door the prewash lamp is lit and the start light is flashing. I've cleaned the filters and the problem persists. Anybody got the solution yet?
  • leswilliams Aug 07, 2008
    i found it was the water pipe was knackered on the back
    how sad is that
  • herald 1 Aug 17, 2008
    Hi i also have got this exact problem have you got it sorted yet if so what was causing it ta andrew
  • chumdum Jan 12, 2009
    is there a solution to this problem or does replacing the water pipe solve it
3 Suggested Answers
SOURCE: Whirlpool dishwasher 1 year old
I have exact same problem with mine. Had Engineer out to tell me it requires new motor. The total cost would be €260. He blamed sand in water as we live near sea. By the way mine survived for 2 1/2 yrs with fairly gentle use
Posted on Jan 25, 2011
heatman101
  • 43501 Answers
SOURCE: Hi Heatman, I have a
Hi Martin,
I would agree with your assessment, if all of the wires are still attached okay....of course I'm sure you already checked that...
so... the logical thing would be the control next...
heatman101
Posted on Mar 23, 2011
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher ADG 957
Try opening the door and holding the start button for 5 seconds to perform a reset. Then try to restart it.
Feb 11, 2008 | Dishwashers
Whirlpool GEW9869K beeps when plugged in and lights flash
pf error is power fault most of the time. circuit board maybe! lots of things to test... but main circuit board is my guess.
Aug 31, 2012 | Whirlpool GEW9868K Electric Dryer
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
Hi Heatman, I have a whirlpool integrated Program 2000 machine APDW/1 which began giving trouble recently with the beeping noise staying going and not been able to move on the wash cycle but by stripping...
Hi Martin,
heatman101
Mar 23, 2011 | Dishwashers
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
Won't start
is the light going off when the door is closed, and on when opened??? sounds as if you having ansd issue withthe door switch, notthinkin the door is closed, try manually pushing the buton in, you should hear it "click", if it doesnt, i would unplug hte unit, nad witha screrwdriver you can pry the switch out from the side of switch. Dont ask me why buit for somereason afetr removing from the unit, it then will"click". somply prerss back inot place.Never actually had to replace teh switch, perhaps it gets stuck!
Jan 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Flashing lights
I've also been having problems with my Whirlpool. Try to turn off the power (unplug, flip breaker whatever) let the machine "re-boot". Then start the cycle again.
Good Luck!
Oct 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Sep 15, 2008 | Washing Machines
Dishwashers Logo
151 people viewed this question
Top Dishwashers Experts
