FixYa.com
Tags:
Umax Astra 2000U Flatbed Scanner
Scanning drops in middle of scanning
posted by ROCKY_WGL on May 02, 2008
hi there,
i had UMAX ASTRA 4100 FLAT BED SCANNER. IF SCAN WITH LOW DPI SAY 100, ITS SCANS PROPERLY,BUT WHEN I INCREASE IT TO 300 DPI.
THE SCANNER DOESN'T RESPOND OR DROPS IN MIDDLE.
I EVEN GREASED THE BAR FOR EASY MOVING.
PLEASE SUGGEST ME.
THANKS
ROCKY
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 02, 2008
Not Rated (0)
jerryg50
Rank:Wiz Wiz
Rating: 84%, 194 votes
Check to see if the computer has adequate RAM's installed to work with the scanner. Don't forget that in the background it is running scanner software, and the operating system at the very least.
It is also possible that there is a buffer over-run timeout error occurring with the USB port processing. There may be an IRQ address conflict. The over-run timeout error from the USB port may not be reported.
Try connecting a USB powered hub between the computer and the scanner. The powered hub will offer some isolation, and being a hub it has some internal memory with data repeating circuits. I have seen this approach fix a lot of problems with digital cameras and scanners.
If it still has the same fault with the hub, then try using the hub with the scanner on different USB ports. There may be an issue with IRQ's and addresses. Moving to a different port will sometimes allow for a different address for reading the scanner.
Past these options that I mentioned, the fault is very involved. If you do not have the in depth knowledge base about how to trouble-shoot this fault, you will have to get some assistance.
Jerry G.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Scanners problems?
Scanners
Live local police scanner on...
recently while browsing the... Answer This...
Scanners
Driver For Umax Astra 5650
Do u have Driver Umax Astra... Answer This...
Scanners
driver for umax scanner Astra...
I would like to have the driver... Answer This...
Umax Astra 2000U Scanner
I have a UMAZ Astra 2000U... Answer This...
umax astra 2000u scanner's...
Hi sir please tell me: I have... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
