ST585v6 router -how to set it up to allow forwarding of ports 5198 5199 & 5200 ? Trying to use it for a ham radio system called EchoLink. Thanks
    Sergeant:
  • 221 Answers
ra config
Configure remote access parameters.
SYNTAX:
ra config [port = <number]>
[mode = <Permanent]>
I found the above command relating to port numbers in the reference manual for your access point. You can try this. If it does not work, below is a link to the Thomson website where you can view the pdf file for your access point's reference manual where you will find many other commands.
http://www.thomsontelecompartner.com/dsl-modems-gateways/products/product-detail.php?id=104
Posted on May 02, 2008
Echolink firewall rules
Access your router with username and password.
Then go to NAT and prot forwarding settings.
Select your port and open TCP and UDP protocol.
Then save settings and restart router.
***If you need any kind of technical assistance you can contact support cell at here
Mar 09, 2013 | Computers & Internet
I am having trouble with Port Forwarding for the Westell 327W Wireless Router.
Hello Michael Yancy,
Seems to be a bit dated... but the AMATEURS that have these ... like them.
Those trying to set them up... Not-so-much
see the videos at:
How to set up your Echolink Port Configuration
Port Forwarding For Noobs Linksys Routers
eHAM.net has the best forum (important)
http://www.eham.net/ehamforum/smf/index.php?topic=76200.5;wap2
May 20, 2017 | Westell Wirespeed VersaLink...
Verizon modem/router will not allow echolink.org
Did you log into the routher and allow TDP/UDP ports like the documentation says? You have to set up a map for those ports in the router programming.
Nov 09, 2009 | Gateway Wireless-B Router (wbr-100)
On my echolink progtam it says to use port 5198 or 5199, how do I do it?
access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
For belkin router http://192.168.15.1
type user nams as "admin" and password as "admin" or blank or "password"
Then go to NAT and prot forwarding .
Let me know if you need more assistanse.
Thanks.
then go to NAT
Aug 31, 2009 | Computers & Internet
I can no longer connect to Echolink
How to set up the ports for Echolink:
  1. Go to this page (link).
  2. Choose the correct router model (if you don't find it, use a model similar to yours. The setup for all Westell routers is almost the same.)
  3. skip the advertisement on the next page (upper right corner)
  4. choose "Echolink" from the list.
  5. Simply follow the instructions.
  6. Voila!
In general:
  1. Important!! (and most often the reason why it is not working): Make sure that yourWindows Firewall is not blocking the application (see Control Panel-> Windows Firewall -> Exceptions) (details also here).
  2. You have to allow UDP destination ports 5198-5199 between Internet andPC in both directions and allow TCP (source port any, destination port5200) from PC to Internet.
If you have any more questions, just come back and leave a comment - I am happy to help.
Thanks for rating!
Mar 24, 2009 | Westell Wirespeed VersaLink...
How to set UDP & TCP port for Echolink
First I assume that you simply posted this under "Linksys > WRT" by mistake and you are using a D-Link router.
  2. Choose the correct router model (almost at the end of the page)
  6. Voila!
In general: Make sure that your Windows Firewall is not blocking the application (see Control Panel -> Windows Firewall -> Exceptions) (details also here). You have to allow UDP destination ports 5198-5199 between Internet and PC in both directions and allow TCP (source port any, destination port 5200) from PC to Internet.
If you have any more questions, just come back and leave a comment - I am happy to help!
Mar 21, 2009 | Linksys Wireless-G WRT54GS Router...
I have a problem with echolink connecting via the Dlink 624
do port forwarding in that you get it in the modem or router any if the port forwading option is there or not
Jan 27, 2009 | Computers & Internet
Router Password
try admin and admin again for password. If that is not it try leaving the password box blank. Good luck Are you sure you did not change the password when you set it up the first time. If you did you have no other option than reset.
Jan 29, 2008 | NetGear WGR614 Wireless Router
Open ports for echolink
Hello Paintah, The link below has a complete walkthrough of enabling these ports!
http://www.portforward.com/english/routers/port_forwarding/Westell/A90-327W15-06/Echolink.htm
Cheers!
Jan 11, 2008 | Westell Wirespeed VersaLink...
Accessing echolink nodes
Please go to the following website and check the port numbers that you have forwarded. Some wireless routers do have issues forwarding ports. http://www.t1shopper.com/tools/port-scanner/ Also, before you use this tool, make sure ICMP is not blocked in the router's settings; if it is blocked all ports would show blocked. Try this and let me know the results. Cheers
May 14, 2007 | Cnet CWR-500 Wireless Router
Computers & Internet Logo
831 people viewed this question
David Payne
David Payne
