Question about Car Audio & Video
Entering radio code
Hi
My fiancee bought a 1998 Renault Clio but the Radio asks for the code.
We have the code but no instruction how to enter it.
Have searched round a few sites with no luck.
The Radio has the following buttons
1 - 6 on presets
RDS
BNDAST
SRC
left arrow MAN right arrow
AUDIO
The code we need to input is 1955
Can you help if possible please
Many thanks
Alan
  • akph May 06, 2008
    Thank you for the response
    I'm sure it would have worked but seems slight problem with the remote control.
    Guess on a ten year old car only to be expected.
    We have now fitted a different player.
    thank you again for the response
  • 476 Answers
To enter the radio code on most Renaults you do not use the buttons on the radio. Instead use the remote control buttons on the steering column.
The remote control has a rotary control, (either vol +/- or track/station +/-), use this to set each individual digit.
The bottom button on the controller moves to the next digit of the code.
When you have the correct code on the display, press and hold the bottom button to enter the code.
You should hear a beep and the radio should start up.
You have 3 attempts to enter the code. If an incorrect code is entered 3 times, then the radio will lock up for about 30 mins before it will allow you to try again. If this happens 3 times, then the radio will lock up permanently.
If you don't have the correct code, or the radio is locked, then there are companies which can re-code the radio.
Posted on May 02, 2008
How do reset my radio code without the digital panel to see what numbers i am entering
Find someone else who has the same radio installed in their car. Write down the sequence and procedure from switch on required to enter YOUR code (even though it won't unlock their radio) and then you should be able to do the same entry "blind" to your radio in your car. You may have to cause the other radio to go into code request to start at the proper point so be sure you have the code for that radio. Clear as mud?
Mar 14, 2015 | 2003 Renault Clio
Error on Renault Clio Radio
i think you should be pressing the 6 button to set code
Mar 12, 2014 | 2000 Renault 181
I recently got a renault clio etoile auto (W reg) , and having problems entering to code for my radio, i have the code and i know how to enter it but the numbers wont seem to change when i attempt to enter...
Hi Ivy, Try pulling the fuse for the radio and leaving it removed for a few minutes. Replace the fuse and try again with the reset code. Regards John
Dec 09, 2012 | Cars & Trucks
Radio code for reanult clio
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Renault service centre and get them to enter this code for you.
Oct 03, 2012 | Renault Clio Cars & Trucks
I need radio code for my Renault Clio 2006 chassi number vf1lb17c533993318
I would go to a Renault Dealer vs: trying to use the phone,
& just ask one time, what the procedure is, for getting
as well as entering the radio code
Not all vehicles require doing that.
If your does,write everything down, as
you will have the battery cables off or other
issues as time passes.
No one on the internet should know your VIN#
or would have a code for anything. That is the
purpose. So if your radio is stolen, it won't work
in something else
May 18, 2012 | 2006 Renault Clio
Renault clio free radio code
Hello , well there is a link http://www.renault-radio-codes.com/renault-clio-radio-code.php , enter your Renault serial and you're cool ;)
Oct 10, 2010 | Car Audio & Video
Radio code needed for renault clio
WE HAVE NO ACCESS TO THESE CODES FOR SECURITY REASONS AND LIABILITY, BUT HERE IS THE WEB SITE THAT CAN HELP.
http://www.radio-code.com/?gclid=COqZmL_Jzp0CFQ0aawodV36crw
Oct 21, 2009 | Philips Car Audio & Video
RADIO CODE FOR RENAULT CLIO
You should go to an Authorised Renault Service Station to get the code. There is no way you can get the code.
Jun 23, 2009 | Electric Renault R26 Radio Control Car
HI, my renault clio radio and clock display are dead
Hi All, the very same thing happened to me. Cold weather broke my radio and the display screen stayed on with the time and temperature but the radio wouldn't work. I rang Renault & they said I need to come in an get a new radio but I put it off. In the end the problem started affecting my battery and the car wouldn't start. But then when I jump started it, it also started the radio again perfectly. Problem solved!
Hope this helps. Good luck!
Jun 02, 2009 | 2004 Renault 181
Renault clio car security code
Hello ...help me pls..
I want radio code for renault 2003 , vf1lbkc526830037
numbers for radio:
model no 22DC259/62F
TOL305
RN259F20389218
PROD NO : FD0602130389218
8200029539TL305
8200 029 539 --C
Mar 27, 2008 | Radio Communications
Car Audio & Video Logo
370 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
