Question about Motorola Mobility PEBL U6 Cellular Phone
Halfway boot up
Well i was listening to music then my pebl just blanks out now when i press the on button the keypad lits up and just goes off even when plugged into the charger
  • 1 more comment
  • Azeazle May 02, 2008
    hmm
  • scotttoms Jul 01, 2008
    When I hit the power button the keypad lights up but the screen or anything else doesn't turn on
  • thedevillive Jul 26, 2008
    When I first got my PEBL, I thought that to charge it you had to connect it to a computer USB port. Now when i turn it on, the keyboard flashes, but that's all that happens.
    Can anyone help me?
    Genius:
  • 1,689 Answers
It is possible that the EPROM in the phone is corrupted. It is also possible that there is a hardware defect on the circuit board. I have also seen a bad battery cause this.
Take your phone to the service rep to properly check the phone. If it only needs the firmware re-installed, this is not very expensive if you have to pay for the service. If the phone requires hardware service, which means a new circuit board or battery, and it if it is out of warranty, then this will be costly.
Jerry G.
Posted on May 02, 2008
Xerox workcentre 7328 showing error code 116-322
Try to Initialize the Spool Disk: NOTE: Initializing the spool disk will delete all jobs in all queues. This procedure can be used when a corrupt job has caused the printer to stop printing. This procedure can also be used to correct certain machine faults.
  1. Press the ON / OFF switch. The power switch is located on the front right side of the machine under the Control Panel.
  2. Wait until the Touch Screen goes blank (this may take several minutes).
    CAUTION: Make sure to press the correct buttons all at the same time. An incorrect button combination may delete all customized printer settings.
  3. Press and hold down the [6] button on the numeric keypad, the [Energy Saver] and the [Stop] buttons simultaneously while powering ON the machine. Continue to hold down the three buttons until the Touch Screen displays several lines, goes blank and then displays lines again.
  4. Release the buttons. The machine will continue its normal boot up procedure to initialize the spool disk.
Apr 12, 2011 | Office Equipment & Supplies
I synced it added music but when i unpluggd it all my music was gone
Press the MODE button to enter "Music Mode". Press the MODE button again and highlight "Local Folder". Keep pressing the MODE button until you reach the album titles and then press the PREVIOUS button and then press the MODE button again. This will bring you to the root directory of your music files. Remember that if you pause too long before pressing the MODE button, it will return you to the first song that appeared when you first entered "Music Mode" and you will have to start over. Once you get to the route directory, press the NEXT or PREVIOUS buttons until you highlight the artist you want to listen to. Press the MODE button again and repeat the last method to select the album and song you want to listen to. Good Luck!!! This is not a user friendly device and even with the instruction manual it took me a while to figure out. I hope this helps.
Jan 25, 2011 | Digital Audio TRIO MP3 Player
I listened to messages and now there is static from the phone even when no lines are connected. Panasonic KX-T7433
Without pressing anything else, press "1" on the keypad. It turns off the background music you don't have.
Carl
Oct 29, 2010 | Panasonic Lands Phones
I have a channel plus mds 6a music distribuiton system and the wall controls are not letting me listen to the tv in one room and the radio in the other room when you press any button it changes the same...
Not trying to be a smart @#@!! but have you carefully looked at the programing for your key pads? There is a sequence pattern that can be followed that will allow you to override other keypads so that one keypad controls everything. Go back and read the instructions on how to program the keypads for different functions.
Jun 08, 2009 | Channel Plus MDS-6A Amplifier
Almost dead phone
YRAG - take the phone and have the flexcable replaced as well as fully service
inuyasha - the lcd needs replacing
psasho - no, replaced the battery as well as replacing the lcd
Jul 04, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorola pebl
I had the exact same problem. Take the phone apart and wipe down he keypad with an alcohol soaked (very mild) q-tip. Let it dry and re-assemble the phone. It all works now!
There are 4 tiny screws under the back cover, unscrew all 4 (home depot carries the little star attachment in most tool sets). Then lift the blue cover off the keypad, the board in the middle stays attached to the headset. There is a little black rubber piece by the USB port keep an eye on it. Also do not pull the board away from the headset, you'll break a tiny silver ribbon.
To re-assemble just tuck the board back in the blue case, tighten the top screws half way. Flip over and tuck the side button connections in, then slip the face plate in top first and press down. Tighten remaining screws and you're done.
Jun 18, 2008 | Motorola Mobility PEBL U6 Cellular Phone
No lit up screen or music
Even I had same problem. When showed it to technical person, he told me that battery has fused off due to water.
Oct 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Motorola Mobility PEBL U6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
