Panasonic cd sterio model sa-ch52 usa unit no result from tape deck connections on motors reading 17v where can i get service manual
  • 4234 Answers
SOURCE: missing ac plug for receiver
If the AC plug is the standard "D" shape with the indents for polarization of the cord on both units, yes ou can.
Dan
Posted on Mar 25, 2008
SOURCE: My sa-ak40 panasonic cd music
My dear friend the belts of your tape sistem are damaged you need to change him.Good luck
Posted on Jun 02, 2008
SOURCE: Tascam 238 tape deck
Common problem with these decks-the capstan motor needs to be replaced- A DIY job if you are careful and have some mechanical common sense- Tascam still sells these motors, around $100
Posted on Oct 12, 2008
tvservice306
  • 458 Answers
SOURCE: Panasonic cd stereo system SA-PM31 won't read cd's
replaced TRV UNIT
part no: RAE0157A-V
Posted on Nov 12, 2009
c1apton15
  • 3400 Answers
SOURCE: instructions needed for use of
About 1/2 way down page is download kink (small box on right)
http://www.usersmanualguide.com/panasonic/cd_stereo_system/sapm03
Posted on Mar 07, 2011
How do I fix error F06 on my Panasonic NV-FJ620??
F06 means the mechanism is locking up after unloading. The cause of this can either be the carriage that the tape sits in, or the loading motor. It's important to check for damage on the carriage.
Incidentally I think this model uses a "K Deck Mechanism".
If you search the web for Panasonic K Deck you should find a PDF manual free.
In fact I have it on my blog site under service manuals.
http://therealchart.blogspot.co.uk/p/technical-help-tips.html
Sep 09, 2015 | Panasonic Televison & Video
Tip
Panasonic SA AK 67 Sterio system need spare
I have one panasonic SA AK 67 sterio system five disk changer
one plastic parts brocken inthe mechanisam area i wold like replace the mechanisam with lence what is the part number i could not find it where i can purchase new mechanisam. please help me
on Jun 30, 2008 | Panasonic SC-AK24 CD Shelf System
Nutone Intercom System IM-4406 . . . the cd player does not work. The unit is about 6 to 7 years old and the CD player has not been working for the past 2 years. It will not even spin around. The trouble...
The unit still getting power?Dose the unit have a tape deck and it is still working?Yes,than CD player section the motor that help the laser eye arm reader to moved and to read the CD disc it is dead.This thing it is out of productions a long time ago.Parts and serviced priced of the Tech. will cost the same as a new unit or could even pass it.If even the Tech. still can find parts for it at all.Just used the Radio and Tape deck sections,if u still have cassett tapes at all.This thing not worth fixing,pretty cheap to buy a whole new unit CD/Tape deck together this day like $60-70 bucks.
Jul 14, 2011 | Broan-NuTone Nutone IMA4406 Intercom...
Ic stk 470-040 where do i find it.is that the main IC
If you are from delhi then you can search the ic in lajpatrai market(chandni chawk).this is not the main ic as the main ic's are "audio power module".If stk 470-040 is blown f61 or some other error is displated according to the systems model and the system is shutdown immediately.
Dec 15, 2010 | Panasonic SC-AK18 CD Shelf System
I have a AIWA brand music system model NSX-V70. It has Tape--Tuner--Video/Aux--CD facility. Problem: 1) CD changer is not operating, it is locked, not opening as a result can not play any CD or DVD. It is...
It is possible that your Cd and teh tape section has a belt problem. The loading belts of the cd and the tape transport is worrn out and results in non action. Since there is no drive the cd mechanism nor your tape mechanism will work. If you have a help around ask them to open the top cover, remove the tray and look inside for the loading motor of the CD. replace and keep the Cd section out. by removing the connecting corrds very carrefully. ZThe tape deck mechanism is within and you will see the belt worn out. The front panel and the deck assembly can be taken out and the belts can be replaced. Attempt to do the job only if you are familiar with electronics other wise get help from a good reputed service shop to replace the motors. However this is not a expensive work but must involve great caution not to damage any parts with inexperience. I hope you understand and find this helpful. Pune is a great place and if you look around find a good sincere technician to help . Good day
Mar 24, 2010 | Aiwa Audio Players & Recorders
I cant find the operators manual for Panasonic audio rack system
 http://service.us.panasonic.com/operman/findmanual.aspx?cat=AUD
This link is for multiple Panasonic sound devices.  I am not sure whether your models are on here, but have a look.
Apr 06, 2009 | Panasonic Audio Players & Recorders
AG-DV2000
If you are seeing tape collect inside the unit, the takeup side is not functioning correctly. This may be as simple as a belt change or idler change. This is not a repair I would suggest that you start with. The alignment of the tape is critical to proper functioning. I would geuss that the "link support mech" is probably just the belt/idler assembly or it is a "mode" switch. In any case, this unit should be sent in for repair. As part of that repair, the conformance to industry standards.
Dan
May 12, 2008 | Panasonic AG-DV2000 Mini DV VCR
Panasonic sa-pm21 sterio cd
The outputs on this unit are defective. This unit requires service. This is a very common model and teh repair should not be too expensive. Figure between $15 and $40 for parts plus the local labor rate.
Dan
Mar 25, 2008 | Audio Players & Recorders
373 people viewed this question
 Grubhead
Grubhead
