I have the awardflash bios update program, and a copy of the new bios, but for some reason the flash program crashes on startup... I'm using win2k sp4, which for the most part behaves itself...
also, I'm looking to overclock the CPU... anyone know what bios changes I can make to get this to work? I've read up about changing the clock speeds, but would like to know if anyone has had success with this particular board, and what settings to use.
Right now upgrading isn't an option, and if I were to upgrade, I'd end up building a new machine...
SOURCE: BIOS in BAD Shape
First thing the problem only with O.S(as per your statement - proper shutdown and restart). Your O S afftected by virus. you must format the full harddisk(all partions) and reinstall your O S. BIOS File always having the .ROM extention file, not BIN file. Pls reset the BIOS using the clear cmos jumper or removing the CMOS battery from motherboard.*****severe virus attack. Dont try to backup****
SOURCE: looking for the best/fastest processor for this board
I'm running a Model: 8 Athlon XP Socket: A Clock Speed: 2.0 FSB Speed: 266 Core: Throughbred Cache: L1/128 L2/256. I think you have to stick with 266mhz front side bus, using the Throughbred Core. I'm not 100% but there are a lot for sle on ebay not too expensive.
SOURCE: bios
as you will probably know Syntax boards are no longer, but are more or less the same as PC Chips boards, but sv2661 is rather old and is not supported on the pc chips site so you can download the last bios update from the link below and instructions on how it's done. http://www.computer-help.net/Syntax-SystemBoard-SV266a-Bios-Upgrade.htm
SOURCE: overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
SOURCE: On board USB and LAN not working
go to your bios and push defult settings if not start from when it was working and see which caponent is cousing the problem
correction, it's the winflash program
