I bought a universal remote from a store and on the back it said I had to get a 4 digit code to make it work on my panasonic television. Your help would be appreciated
    President:
  • 2,712 Answers
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
Remote code for my Panasonic TV Viera TC-P50U50 to program my universal remote
Pensonic TV 3 Digit Remote Control Codes:
095
863
261
Pensonic TV 4 Digit Remote Control Codes:
3778
3779
2186
To program most universal remotes to work with your Pensonic TV:
1 - Hold the setup button until the light stays red or green.
2 - Be sure the light stays illuminated.
3 - Enter one of the remote codes provided above.
4 - Remote blinks and code is saved.
Nov 14, 2017 | Panasonic Televison & Video
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
I have a LG remote for a insignaTV any codes for it would be help full. Bought a remote from good will for my Lil t.v and now can't find how to program it to t.v.
Your LG remote must be universal to program your Insignia TV. If it is, use the code search feature to find something that will work. If a search through all codes stored in the remote fails, you may have to trek back to Goodwill to buy another universal remote or buy a new universal remote at a discount store. All universal remotes do not store all possible codes.
Jun 30, 2016 | LG Televison & Video
I bought an element tv that came with a nutek universal tv (used ofcourse) and now its come unprogrammed. I need the codes. Any help will be appreciated..
Codes to operate your Element TV:
Newer codes 5 digit:
11886
10178
11687
12183
Older codes 3 digit:
005
028
043
048
076
096
155
004
051
127
151
153
154
231
236
238
247
252
168
121
ON MOST REMOTES:
1. Turn on the TV.
Your Element TV can be controlled with a universal remote and work with RCA remotes, Comcast, DirecTV, Charter, and more.
Read more: http://codesforuniversalremotes.com/remote-control-codes-for-element-tvs/#ixzz40ImSP8T7 Remote Control Codes For Element TVs Codes For Universal Remotes
Feb 16, 2016 | Universal Televison & Video
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
Jan 25, 2016 | Panasonic Televison & Video
Bought a new Sony flat screen and the channel changer on the remote wont work
If it is its original remote control, there should not be a problem like this; as all the other buttons works properly. If it a universal remote control, some buttons on it might not work properly. The only thing to check is, try with an other set-up codes to Sony brand TV, with the universal remote control.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops.
Check this link too. http://remotesearch.blogspot.com/
Apr 26, 2014 | Sony BRAVIA Televison & Video
I need the code for ge universal remote rc24993-c to connect to a sony television please
Universal remote allow you to control multiple electronic devices with a single remote. You can use the remote to work your TV,DVD player, cable boxes and other devices from the comfort of couch.Philips is a popular manufacturer of universal remotes.to program a GE remote for SONY TV,you will either need to input the device code or perform a code search
direct entry
first.turn on your TV manually. next.press down and hold set-up on the remote.the red indicator light will stay lit.after that.press the TV device button to let the remote know you wish to program a television then.enter your device four digit codes on the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the number zero in the beginning of the codes finally.test the remote to ensure it works.with the turned on,press the channel button and see if the TV responds..if it is work the remote programmed and you are done,if it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
Mar 09, 2011 | Televison & Video
Please can you help find a code for rca tv. using a philips remote?
It will not work you hve to Have RCA or Universal Remote that can program up to 4 different products,Go Dollar Store Buy universal Hant unit $5.00 it will have code book with it!
Oct 04, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Remote control for the LCT3285TA
Good News! I found a universal one that works with my LCT3285TA. It's the GE Universal Remote Control, 5 Device w/learning. SKU: 24950
It isn't very expensive, and can be found at many Target stores.
You can even check its availability in your local Target on their website. I haven't deciphered the date code on the packages, but look for ones with an 8 or at least a 7 in the 4 digit code on the back.
One of the AKAI codes in the TV section of the code list works fine with this model TV. I forget which code it is at the moment or I'd list it here.
Good Luck
Feb 08, 2008 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
