Question about LG Shine KE970 Cellular Phone
Cant Dialup Hello Im am not able to dial up and go onto the internet with my phone although i have set it up, correctly and entered all the required dial up number and put in all the ISP info, am i missing it some where or this phone does not dial up to connect to the internet or retrieve email
    Novelist:
  • 124 Answers
U dont need such dial up connection.
U have to set up the GPRS connection. U have to name access points and IP addresses as accordance to sim operator.
Send me a feedback and rate my solution.
Dont forget to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
Posted on May 11, 2008
How to configure internet connections to my samsung c3510?
  • Install latest pc studio from Samsung.com
  • Than connect your corby pop with pc.
  • Your driver will install automatically.
  • Than manually create a dial up modem -- start> accesories>communications> new connecion wizard>"Next"> click " connect to the internet"> click "setup my connection manually">click"next
  • ">click "connect using dialup modem">.enter "ISP name"> etc etc
    (ask the setting by calling customar care)
  • Dial *99#(ask custumar care for dialing number) from your phone that helps to connect it and you will find that your corby works with your pc and you can access the internet
  • Jan 17, 2011 | Samsung C3510 Cell Phone
    Hi I have downloaded the pc suite for lg kg 195 but I am not able to connect to the internet. It's not able to establish the dial up connection. Please help me to connect using airtel sim.
    Make sure that you can see the phone's modem in the modem section of device manager(Preset in Control Panel). For airtel connection you have to enter the APN(Access Point name) as "airtelgprs.com" in the PC suite to connect to internet and the dialup number is *99#.
    If your pc suite dont have a option for entering the APN then you can manually enter it here-->Go to Control Panel>>Device Manager>>Your phone's modem Properties>>Advance tab>>In Extra Initialization Commands enter this (+CGDCONT=,,"airtelgprs.com") without brackets and create a dialup connection with *99# as dialup number using ur phone's modem, Username n Password field should be blank.
    Sep 22, 2010 | LG KG110 Cellular Phone
    Cant browse internet using n99i (philippines settings)
    Better way to use it as a Normal DialUP. but u will require a laptop/computer to use this dialup
    Sep 22, 2009 | Cell Phones
    Internet will not connect through dial up
    Check the basics...RJ11 connected to pc, username and password reentered, restore IE settings in internet options. Check dialup number is correct and that dialup modem has no issues in the pcs device manager. Not much more can go wrong with dial up as it's such a simple service.
    Apr 19, 2009 | Computers & Internet
    How d o I dial the Username and Password From this router.
    If you have a dialup internet connection the router can not directly help you, because the device that you are using for dialup (your PC) needs to first dial up your ISP using the telephone and then once connected it will use PPP to setup the IP Connection, at that point your within the PPP stack it will send your Password and Username. When that is all done you have connectivity. The router assumes that your connection by nature is either DHCP or PPPoE, not PPP or SLIP as with a dial up connection
    What you need is a device that has dialup capibilities, and an internal PPP stack to allow for connectivity to the ISP while allowing for a connition to the router. This can be done by connecting one of your PCs (with Internet sharing enabled) to the internet via dialup and using a second ethernet connection to your router, then from the router you can connect your other PCs.
    This method involves setting up two different subnets so here is a suggestion:
    1) On the PC set the ethernet LAN facing connection to an IP Address of 192.168.10.100, netmask to 255.255.255.0, Gateway to 192.168.10.1 no DNS
    2) On the router set the WAN IP Address to 192.168.10.1 and the DNS to the DNS provided by the ISP.
    3) On the router facing the LAN (your network) set the IP Address to 192.168.1.1 and thell the router to act like a DHCP server.
    This way you will be able to connect your PCs to the router and have it serve as a permanent connection to the PC which will still have to dial out but you can send a periodic ping sequence to keep the Internet connection up. and connfiguer auto-dial if the connection goes down.
    I hope this helps
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc.com
    Feb 16, 2009 | NetGear WGR614 Wireless Router
    Wizard wont create a dialup connection using vista i have updated the modem drivers and the modem is in my device manager
    Hi
    Follow these instructions to create a dial-up connection on your computer. Then you can get on the Internet to receive/send email and browse the web.
    From the Start menu, click on Connect To
    Click on Set up a connection or network
    Click Set up a dial-up connection
    Click Next. Enter the required information for the connection:
    Dial-up phone number: 513-520-1135
    User Name: (the NCF accountID that was assigned to you)
    Password: (the password chosen by you when you registered)
    Remember this password(check this box)
    Connection Name:NCF Internet - Libertel
    Allow other people to see this connection: Check this if you want this connection for all users on your computer (recommended)
    Note: if you have Call Waiting, temporarily disable it for the duration of your NCF connection byusing *70,,613-520-1135 as the phone number.
    *The NCF dialup phone number is in area code 613 in Ottawa. Please note that long distance charges may apply to modems outside of your local calling area.
    Click Connect to create and save this connection.
    You have successfully created a Dial-up Connection in Windows Vista.
    To connect to the NCF using the connection you have now created, follow these steps:
    1. Click on Start, and then Connect To.
    2. Left click on the NCF Internet - Libertel dialup-up connection and select Connect at the bottom.
    3. The Dial-up windows will come up. Simply click on Dial and your computer will connect to the NCF
    Jyothish
    Jul 18, 2008 | Computers & Internet
    Is there any way to increase download speed on my dialup connection? Phil
    making sure you have the latest drivers for the dialup modem is about the most you can do. not sure if you've considered dsl or cable internet, but its cheaper than paying for dialup service and a phone line. (unless you don't have a cell phone and need the home phone line.)
    Jun 27, 2008 | Acer Computers & Internet
    Cant connect to internet via dialup
    you have to call your telephone company as they will gona provide a login name and a password and will walk you through setting up a connection
    Jun 07, 2008 | Acer Aspire 5100 Notebook
    Dial up problems
    In order to help you further I need the following questions answered:
    What OS are you currently running?
    Are you connected to a landline dialup or DSL?
    Because if you are using dialup, that is your problem right there! Most of the people who are still using dial connections instead of DSL or Cable will have these problems. Technology is evolving so fast that even the phone companies seem to have trouble tell their customers that dialup is a problem because they are not supporting it anymore. They are selling it, but not supporting it because of DSL, FIOS, and cable.
    You may want to upgrade, because even if the problem is resolved you will still encounter problems due to the lack of support!
    Nov 26, 2007 | Dell InspironTM 600m Notebook
    LG Shine KE970 Cellular Phone Logo
    62 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
