Question about Gateway Cable/DSL Router - 4Port [ Belkin F5D5231-4 ] (108807)
Signal problems - F5D5231-4 (Belkin 4-port wired router) through virgin media set top box
I've noticed on both machines on my network (wii & PC) that from time to time the signal just drops from the router for a period of a couple of seconds, then returns.
This never happens if I plug directly into the digital modem.
Its not really a problem for data transfer, but its really annoying when gaming as it usually drops me from the server..
Do you know what could be causing the problem?
  • mqshah Feb 22, 2009
    I have the same problem and have always had to bare with it which has become really frustrating recently. If I can, I normally just plug my PC in directly to the modem when gaming or downloading.
    I've read upon this for a while now and I think it might just be a faulty unit.
  • david_heal Mar 25, 2009
    Every time i go to play a game on fifa the connection drops from the xbox and the computers its really annoying :@
  • 156 Answers
I have heard of this problem before with these belkins,,, usually its like a SpikeDrop every like 5-10 minutes. Frigging kills any kinda gaming experience. Ok you need to update the firmware on that router and DUMB down the security settings and turn off that file share **** on the router too. If none of this helps just return it and buy a better router or a linksys.
Posted on May 02, 2008
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
Belkin g router and Virgin - account not accepted
can you get a phone number?
the router may be block by Virgin Media, so that way people can't steal internet from it (that is if you have it unsecured) you may have to set it up with virgin over the phone, or have a local broadband provider try to set it up
Jan 08, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
"settings not the same on the router as pc " says the message...
has the router got a wlan port if so then ask virgin to send you a seperate modem as the set-top box has conflicts with routers this is all the help I can give
Aug 26, 2008 | Zoom Computers & Internet
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Jul 23, 2008 | Belkin Computers & Internet
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
Belking54g router problem
update the firmware. go to http://192.168.2.1/index.stm and download the newest version
Mar 18, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Router
Connect the modem to the WAN port of the router, then connect the computer that was connected to the cable modem to any port on the router. After you recieve an address from the router you will then connect to the belkin setup page. go to IE and connect to 192.168.2.1 I think the belkin routers password is blank. After going to the setup page on IE you will go to the mac address clone, click clone computer address. Then reboot the router, or renew the wan dhcp. Good luck.
Jan 28, 2008 | Belkin (F5D5231-4) Router
Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
Oct 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Gateway Cable/DSL Router - 4Port [ Belkin F5D5231-4 ] (108807) Logo
536 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
