Question about Microsoft Xbox 360 Console
Picture but no sound
My Xbox has sound but no picture i tried everything even bought new cables it didn't work
  • Tom Kilroy
    Tom Kilroy May 11, 2010
    First, have you ever had picture before?
    What cables are you using... (AV yellow white and red, HDMI, or YPbPr red green and blue?)
Your tv might have a short
Posted on May 13, 2008
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Joseph Siliezar Canada Hello Jackson nice to meet you, right now i'm having problem with my xbox 360. I hope maybe you could help me, i did everything i could to fix my xbox. Right now whatever i turn on...
there is a switch on your AV cables, check to be sure its on the HDTV setting. the switch is located where you connect the cable to the back of your xbox, if the cable is plugged in, it will be on the left side.
Jan 16, 2010 | Microsoft Xbox 360 Console
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
Easy cap from xbox to computer - can hear sound but no picture
I've heard that DVD Rs don't play on Xboxs.  It used to be on the first generation Xbox would give you an error.  If you are getting sound and no pictures,  it's a good indication that the Xbox doesn't have the correct decoder to read the DVD even though playing store bought movies from it still works.
I think they did this to keep people from pirating games rendering home burned DVDs useless when played in the machine.
Oct 21, 2008 | Ulead Videostudio 8 for PC
Sound with no picture
Have you looked at the side of the cable and made sure that the switch is set correctly? you have to select either HDTV of AV I believe. If that isn't the problem, try hooking it up through a different input on your television. I don't think it's your xbox because with any hardware failure, you would get the RRoD (red ring of death). I would definitely troubleshoot the TV. Try to hook up a regular DVD player in the input that your xbox is in and see if it works.
Jan 29, 2008 | Microsoft Xbox 360 Console
No picture or sound
perhaps the xbox is causing the tvs to malfunction. i would get a new one. remember that xbox is giving everyone a 3 year extended warranty on the xbox 360
Jul 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
