Question about Optoma HD72 Multimedia Projector
Microtek cx6 I power up my projector and it works fine for several minutes then the light goes out. Turn it off and back on it does the same thing. What could be the cause? I have an optoma hd70. with 610 hrs of lamp usage. the projector works for around 60 mins. then the lamp flickers and lamp fails. after power reset it work again for another 20 min. and so on. If i switch off the bright mode the same thing happens after 2-3 hours of usage. sameer
I've had the same problem with my projector three times (usually whenever there's a sports championship). You just need to call optoma, get an RMA number, and ship it to them. Theoretically they'll fix it under warranty and send it back free.
Posted on May 28, 2008
Won't turn on
How long has it been running, projectors ALWAYS turn off when the overheat remove anything covering the cooling vents and it may have dust inside which will compound the problem.
Solution wait for 5-10 minutes.
Dec 26, 2013 | Epson PowerLite 61P Multimedia Projector
I replace one new lamp C121 but no power in my projecteur lamp
the thermal fuse 1-900-222-47 could be the issue see service manual
Jul 23, 2012 | Sony VPL CS4 Multimedia Projector
My sony vpl-cx6 projector does not power up
If the fuses are ok, and there is no st by light,
replace ic3100 in the psu order no.A-1302-316-A
Nov 13, 2009 | Sony VPL-CX6 Multimedia Projector
Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Jun 26, 2009 | Sony VPL-CX6 Multimedia Projector
Sony VPL-CX6 lens protector not opening
Your lap its not working , mabe is over 2000 hours , you need a new one.
Mar 18, 2009 | Sony VPL-CX6 Multimedia Projector
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
Microtek cx6
Hi there
Firstly check when the Projector is switched on , if all the fans are running.
If they are , then it can only be one of two things - either the Powersupply or the Ballast that has gone faulty.
Is there any indicator lights on the unit that flickers , and also what colour ?
Take out the lamp and check for any irreugularities on it like discolouration ( vein like looking marks in either white or black ) or if there is any bubbles on the shaft of the lamp. In which case the lamp will be at fault and will need replacement !
Apr 17, 2008 | Microtek CX6 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
VPL-CX6 PROBLEM
If the fuses are ok and there is no st by light,
replace ic 3100 in the psu, order no. A-1302-316-A
Sep 24, 2007 | Sony VPL-CX6 Multimedia Projector
Optoma HD72 Multimedia Projector Logo
305 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
